Thermometer Reading Off - 2015 Trail
Greedy
I have noticed that my in-dash thermometer is reading about 10 degrees colder. This morning, it was around 30 degrees outside, and my dash was reading at 21 degrees. This is while I was stopped and driving. Anyone else experiencing this problem?
Mine only had 37 degrees this morning but I knew for a fact that it was F&#%#$@ing cold....
Seriously though, wonder if it's not factoring in wind chill...
Haha - arctic blast right?
Mine was doing it sitting still though - no wind. Does anybody know where the probe is located?
Don't know where the probe is but is it possible it was iced up? I've had the same issue after spending a couple days off road. A quick wash down cleaned my probe up wherever it is.
I was actually parked in my garage overnight where it was about 50 degrees (according to the garage door opener control). When I started up the truck, it read 42 degrees. It always seems to be about 10 degrees colder than any other readings...
you sure it wasn't set to "C" instead of "F"?
mine read 16 this morning, but that's a heat wave this week. yesterday was a high of 9.
Yeah- there was a big F right next to the readout. I will try toggling back and forth between the two and see if it makes a difference.
THanks.
THanks.
Unless you live in the Southern Hemisphere, if it read 42° this morning it was surely °F. 42°C would be 108°F and that would mean your truck was WAY off!
88625P in the picture is the Ambient Temperature Sensor P/N 88790-22150
If you pop the hood, it should be on that center post in front of the radiator.
Thanks again. Ill check it out. Any procedure on checking if the probe itself is good? Maybe a resistance reading at xx temp or something?
Min: -23.3°C (-9.94°F) (Also the Temperature that shows when the circuit is Open)
Max: 65.95°C (150.71°F) (Also the Temperature that shows when the circuit is Shorted)
10°C (50°F) - 3.00 to 3.73 kΩ
15°C (59°F) - 2.45 to 2.88 kΩ
20°C (68°F) - 1.95 to 2.30 kΩ
25°C (77°F) - 1.60 to 1.80 kΩ
30°C (86°F) - 1.28 to 1.47 kΩ
35°C (95°F) - 1.00 to 1.22 kΩ
40°C (104°F) - 0.80 to 1.00 kΩ
45°C (113°F) - 0.65 to 0.85 kΩ
50°C (122°F) - 0.50 to 0.70 kΩ
55°C (131°F) - 0.44 to 0.60 kΩ
60°C (140°F) - 0.36 to 0.50 kΩ
It's funny that it will only go to -10F considering that many people will experience colder temps every winter. Our low last night was right around that. On the other hand, it will go to +150F, at which point I will be dying a very uncomfortable death. anyways, thanks for showing where the sensor is, the last time I went through the car wash mine went crazy. After about an hour, it was all dried out and went back to normal.
That's odd. Here is -17F. I saw it go down to -28F, but no photos.
:shrug:
That's what the FSM says... I never bothered to actually check the ranges on it to be honest?
Edit-
Went outside and blasted my 4th Gen's unit with canned air to flash freeze it, went to -22F ... unfortunately it does not seem to want to go back up, even after running it under warm water... so I'm gonna say it doesn't like much more than -22F? lol :doh:
:shrug:
Sir, I commend your commitment to empirical research! May your sensor survive the trial.
its rated to go much lower, I think -39F. this is the lowest I've recorded on mine.
and as you can tell based on Bilbo's screen, I removed my eco bar via techstream :)
044runner4
