brockeverly
How far are you leaning? What have you tried to correct the lean?
I am currently low on both the front and rear drivers side with my Daystar lift. My new lift kit comes with an OME trim packer which will make up 5mm (approx .2"), I assume that the .2" will equate to a larger number due to the suspension geometry, but maybe not. I am not sure how it will help at all with the rear, but we will see. I really, really, really hate this lean. I have tried airing up the rear drivers side load leveler all the way up to 30psi with only 5psi in the passenger side and it had little to no effect on the rear lean.
Current ground to fender measurements:
Drivers Front - 37.75"
Passenger Front - 38.25"
Drivers Rear - 38.75"
Passenger Rear - 39"
