Time to replace speakers - suggestions?
Now im trying to find matching tweeters for my dash speaker as its cracking.
The dremel is your friend :thumb3:
P4020233.jpg~original
A suggestive comment is not limited to the words "I suggest" and your posting appears very suggestive to me but maybe I'm reading to far into it... That aside I completely agree with you on everything you have stated. The jbl headunit, amp and the way they control the system is a pain compared to nearly any other system on the market, factory or otherwise.
your right, my tone cant be expressed across the internet. its possible now re-reading it that i was suggesting. :)
I had focal components all around which sounded amazing, I'm switching to Kenwood's excelon series XR-1800ps in the front and KFC-X783Cs in the back since i'm sponserd by a local car audio shop.[/QUOTE]
in the USA there are no xr-1800ps, just xr-1800p and no kfc-x783c
how ever if [MENTION=44866]ARK_SWAMP_RIDER[/MENTION] wanted the usa equivilent with full 2 year warranty it could be had for around $300ish
i've bought mine thru amazon because i have Prime. Really saved me there. i did research elsewhere then bought on amazon.
JBL connectors
Amazon.com: Metra 72-9300 Speaker Connector for Select Mazda/Nissan Vehicles: Car Electronics
6.5s
Amazon.com : JBL GTO638 6.5-Inch 3-Way Speakers (Pair) : Vehicle Speakers : Car Electronics
6x9s
Amazon.com : JBL GTO938 6 x 9-Inch 3-Way Loudspeaker : Vehicle Speakers : Car Electronics
amazon is not really a great place to buy car stereo since warranty will be the issue. just buyer beware.
amazon is not really a great place to buy car stereo since warranty will be the issue. just buyer beware.[/QUOTE]
ive returned broken items to amazon no issues and full refund :shrug:
its so cheap ill buy another set is how i view it.
correct, you returned it to AMAZON. not warrantied thru manufacture. i'm just sharing info and i can get real deep into why amazon is bad, but thats another day :)
btw- my expert eyes say its a 3.5" speaker :P
... but want to do it right so I'm not going back in a few months and doing it all over again.
You say this like it's something you've done before....
I spent the first weekend after I got my 4runner replacing the JBL system because of the Limited connectivity. Fortunately I already had an HU from another vehicle to start with.
I replaced the JBL amp and speakers with MB Quart 6.5" components (front and rear) and a JL 320.4 amp. I think I spent under $300 altogether through eBay and Amazon. Not the most reliable sellers but they've been trouble-free for 4 years and still sound tremendous. I left the center speaker out; have thought about putting one in since my HU does 5.1 but never did since most music is made for stereo.
I tried going back the JBL HU with low level inputs on the amps for a brief period but the sound quality was so diminished that I couldn't handle it after getting accustomed to the aftermarket unit with RCAs. I've changed head units 2-3x since then but the speakers and amps have remained and continue to sound crystal clear. Not the loudest system on the block but it is crisp.
I've also had good luck with JL and Infinity component speakers in the past.
Haha! Unlike the suspension, I'm fine with the factory system. Maybe it's because I haven't heard anything better for comparison. My thought is if the Infinity/JBL speakers are even marginally better than stock, that should be good enough. My main concern is once I start, where do I stop? Is it just new front door speakers (the only part I actually "need"), new head unit, new amp, etc.
It really depends on what your looking for regarding sound wise.
are the focals for sale?:hug:
rainbow, focal, morel, hertz, inifiniti kappa, dynaudio, and my personal fave:eyebrows: diamond audio.
most of these are higher end, but some are very affordable.
I would highly suggest upgrading that head unit and amp.:tongue1:
After thinking it over for a few days, I'm going to go with just replacing the stock speakers with the Infinity Reference speakers. Planning on 6x9 fronts and 6.5 rears. I'd love to do a full swap, but I've got other priories at the moment and just need the blown speakers replaced.
That said, I'm looking for suggestions on tweeters. I would like to replace the tweeters in the front doors and also the center dash speaker. I looked into the 3.5s, but I can't find a matching speaker in this size. Infinity offers a 3 ohm 3.5", but no longer has the 2 ohm version. I did find some 1" 2 ohm tweeters. Which would be the better option?
http://www.amazon.com/Infinity-Refe...e=UTF8&qid=1404138913&sr=1-1&keywords=3002cfx
Amazon.com : Infinity Reference 1031t 1-Inch, High-Performance 150-Watt Textile-Dome Tweeter (Pair) : Vehicle Tweeters : Car Electronics
are you planning on eventually upgrading the HU and Amp?
if you get the component 6x9 set , you will get the tweeters with it and they come seperate so you can mount them in the t4r factory location.
I would suggest whichever brand you choose to get silk tweeters . THey sound better than the aluminum.
p.s. wish you would spring for the infinity kappas over the reference series:pray:
I did the front and rear speakers. Put in JVC CSV series 6x9" (used Metra 82-8146 6" x 9" Speaker Adapter) in the front and 6.5" in the rear. In the rear I cut the speaker out of the frame and used it as the adapter. Also used these wire adapters x4 (Metra 72-8104) to make connections easier. Cost me $108 through Amazon shipped and took me a few hours. They sound great to me but I'm note an audiophile. To many rock concert when I was younger. Probably couldn't tell the difference if I did go high end. :ear:
I would like to upgrade the amp and head unit eventually, but not sure when or if that will actually happen. I guess my end goal is to have a set of speakers that work well with the OEM setup, but also that would be good enough to keep if I upgraded the amp/head unit in the future. Sticking with a 2 ohm setup seems to keep me pretty limited in options.
I wasn't really looking at component sets, the speakers mentioned (Infinity/JBL) would just be 2/3 way speaker and I was planning on separate tweeters. I haven't found any other 2 ohm options (no 2 ohm component sets).
I just looked at the Kappas. These didn't show up initially because I was looking for either 6.5's or 6x9's. I only see Kappas in 6 3/4. Will the 6 3/4's fit in the front doors? I've seen adapters for 6.5's, but not 6 3/4's.
This brings up another point. I am planning on upgrading the front and rear doors, but only the fronts are actually blown. Would I be better off to spend more money on the front, and leave stock speakers in the rear? If I did this, I could probably go with the Kappa's (assuming the 6 3/4's fit).
I was looking at these, but they don't include silk tweeters:
Infinity Kappa 60.11cs 6-3/4" component speaker system ? also fits 6-1/2" openings at Crutchfield.com
I also found these. They aren't 2 ohm, but they do include silk tweeters and I've really liked my JL sub.
JL Audio C2650 Evolution™ C2 Series 6-3/4" component speaker system at Crutchfield.com
If you go with a speaker that has a higher ohm rating it's actually less taxing on the amp...but it also means the speakers won't be drawing as much power. If the speakers are efficient enough..you'll never notice the difference. But be careful of mix have a 2ohm woofer and a 4ohm tweeter (or visa-versa).
If you haven't bought anything yet I'll make a smoking deal on a full set of stock speakers out of my garaged low mileage 06. They are the JBL synthesis models. I just did a full blown system swap. If the dash speaker isn't hard to remove I'll pull it also for you.
if you get a 2ohm set up, and you do replace the HU and amp, you can replace the amp with 2 channel 4ohm amp and run the speakers in series to a 4ohm load on the amp.
The 6 3/4 kappas should fit, maybe with minor work, check the depth to be sure, you dont want your window not to be able to go down all the way.
as far as keeping the rears and just upgrading the fronts, you can if you keep the same ohm speakers.
what you could do since you already have the JL sub, is keep the speakers and amp JL and do a component set up front(tweeter mounted in factory tweet location), coaxial in rear(two or three way) and a JL 5 channel amp so you can power the 4 door speakers and sub off the same amp.
Thanks to everyone for the info.
This would be ideal, but it runs into much more money than I'd like to spend on audio at the moment. Between my 4runner, truck, and other hobbies, I've got a lot going on and a full audio upgrade isn't of the highest priority. However, with the stock front speakers blown, I do have to do something pretty soon.
I'm pretty certain I've figured out what I want to do. Most everything I've read says to spend extra on the front and not to be as concerned with the rear. My thinking is that if I buy the 6.5" Infinity Reference setup, I can run that in the front for the time being. When I have the funds available for better quality speakers (and possibly an amp/head unit), I can move the references to the rear doors. From the comments here, I think I would be fully satisfied with just those speakers in the front, but if not, I could still use them for the rear so it wouldn't be money wasted. Anyone see any issues with this?
Also, I'd opt for the full component set instead of piecing it together without the cross overs.
Amazon.com : Infinity Reference 6030cs 6.5-Inch 270-Watt Two-Way Component System : Component Vehicle Speaker Systems : Car Electronics
seltzernator
