Tire chains or studs?
With all that said. Can someone recommend a Tire Chain brand they have used that performs well and has lasted a long time? :thanks:
I've used 4.5mm reinforced Diamond quick fit and never had a problem. They have the advantage of being easy install/removal. They are also available with ONORM rating (supposed to be the toughest spec in the world). Pricey but to me, worth the extra $$$. Tire Chains by TireChains.com
Thanks, I have read multiple customer reviews off off "Google"
I was wanting reviews from respected members on this forum.
Such as MeBe4running which didn't take much of 2 minutes to share a "preference"
Thank you!
Whoa! Was that sarcasm? Did you try what I suggested?
FYI, the Google search window, DOES search the 5G T4R section. This has been discussed here, hence my suggestion. Yer Welcome.
Nothing wrong with Blizzaks. I'd probably go for a set of Blizzak DM-V1's if they came in a studded version.
I have had Blizzaks on all my vehicles for the winters here in CT and they are a great tire. I have Blizzaks on my 3rd Gen and the trucks a beast in the snow.
Thank you!
YOU BAS ****!!....lol
I only have experience with the old "chisel tooth" type..that you could climb Everest with...but the newer Thules are awesome...my hero Brad uses them...
and if Brad said it..I believe it..and that's final.....
Brad's Consolidated King Kamper Trailer Thread - Page 2 - Expedition Portal
and besides, it's Friday night..I only have two Yuenglings in me...and there's just not enough alcohol coursing through my veins to make it all go away...
so check back in 20 mins.
:cheers:
:cheers:
LOL ! Sadly, I will still be at work, so I'm sure I'll check in 20 developments.
Thanks for the suggestion though! I appreciate anyone's time and input.
Not Sarcasm, just wasn't what I was looking for. I said Thanks :)
tyler_ross
