Tire companies
I dunno if I would exactly call them be ridiculous for following recommendations from a higher order. You can argue what is a repairable tread block all you want; but just because it looks like a repairable tread, works like a repairable tread, does not mean it is a repairable tread (according to RMA), lol.
The Rubber Manufacturer's Association makes it pretty clear cut on what can or cannot be patched, and the outer tread blocks are not part of it, plain and simple. See below:
If you're curious, here's a link to how they recommend tires to be patched: http://www.rma.org/wp-content/uploads/prp_wallchart1111.pdf
If I understand correctly, these are the guys that pretty much develop the safety standards for all the tires on the road today here in the US, so it's kind of hard to argue with their guidelines from a legal standpoint.
I am pretty sure BJs is not in it just to make an extra buck by pushing a new tire; probably much more likely that BJs on a corporate level does not want to deal with the legal consequences (like most larger chain tire shops).
Kind of sucks that we live in the world where everyone sues at the drop of a hat, so if anything we have our peers to blame as well.
With that said, if you do plan to patch a hole that far out in to the shoulder I highly recommend one of these mushroom style plugs:
Patches at the shoulder go through a lot of more flexing and stress I think, and you really need all the surface area you can get when sticking it on. I've had pretty good luck with these type of plugs with holes right at the edge of the shoulder.
Not stating that this is right or wrong, just stating that it works for me, but your mileage may vary :cheers:
Technically the rma is not the authority on tire repair, that falls to the manufacturer of the tire and because of liability reason no manufacturer states that a tire can be safely repaired. Let's be realistic, if a tire is repaired properly following rma guidelines and fails, the rma is not liable, and the retailer who repaired the tire still is.
The flexing of the tire is not the concern. Tires flex continually as they roll. The concern is the strength of the area that is to be repaired. The reason you don't repair sidewalls is because there is no steel. The steel belting is in the tread area. The picture is a poor guideline. I don't know how you could point the area on a tire like a BFG A/T.
Out of curiosity, did your son drive on the tire while it was flat for a little while, or was it plugged before going flat? Driving on a flat for any amount of time can cause damage internally on the tires, so it's really best to pull the tire off the rim and give it a good inspection before putting it back into service.
The biggest issue with just plugging from the outside is you don't get to inspect the inside to see how it looks and decide if it's safe to repair or not...
He did not drive on it at all. It was flat in the parking lot after work and he changed it right there. After plugging it he drove it for several months without a problem and then it blew out going 10 mph turning at a intersection in town.
As was said in a earlier reply take it to a mom and pop shop that still uses old style tire plugs. The exact same thing happened on my wifes car and the dealer wanted 300 dollars for a tire because they said it couldn't be repaired. I took to a local tire shop that fixed the hole in less then 5 minute. We had zero problems from that tire for over 30 thousand miles. Good luck getting it fixed
I've had good luck getting tires patched in my teens and 20s. Knowing what I know now, I wouldn't risk it.
edcultural
