MSBX4RUNNER
I checked the tire pressure and everything seems fine. The lows at night are in the 50s and the highs are in the mid 80s, do you think it is just the changes in the weather recently?
I don't know if you have had any service done on the tires recently but I had an issue with a tire pressure sensor - it got all corroded so it failed.
The pressures where complete good - went to check it and found that they sensor was the issue. Expensive fix...oh well.
Hello all fellows 4Runners. I read all and many blogs about this tire pressure issues. But I cannot find the clear answers.
1. What is the normal tire pressure for the 4 tires and the spare?
2. So if the pressure drop by 1psi for every 10 degree F, will the pressure increase if the temperature increases? Let say I inflate it at 35psi at 60 degrees F, then the temp is up 90degrees during the afternoon (Phoenix temp), will this pressure stay the same or increase?
3. What is pressure should be set for cold weather and hot weather, like AZ vs MA?
I only wish the manual has all this detail. Unfortunately, this 4Runner's owner's manual are not well written or illustrated.
BTW I have 2007 4runner - V6. Thanks for answering my questions above.
