toyota 0-20wt engine oil
catrains
I own a 2016 runner . used mobile synthetic 0-20wt SN . has 24,000 miles on it ..
I read on forums that the Toyota engine oil SN plus has moly 800PPM .. this was reported by members that the engine quiets down.. less ticking.. I did the oil change today .. could not believe how quiet the engine was .. I replace the oil 7500 miles hard to check the oil on stick it is so clean.. no oil use but the engine ticks on cold start.. problem solved .
mobil synthetic only has 60PPM of the moly .
members also stated this Toyota oil gave them 1-2 MPG more than the mobil synthetic . I will post back on the MPG change with this oil.
I also did the drive shaft greasing today .. looks perfect under the runner .
Still blows me away, 0w-20 just seems so thin. Even though I don't have a new 4Runner, that is a very interesting find!
Has anyone tested this with Oil Analysis?
[MENTION=138935]catrains[/MENTION] Do you have any left? I work at a place that can test it. Seems interesting. Would like to know for sure.
Nevermind......I shoulda looked it up on Bobs Oil Guy website first.
my MPG increased 2 MPG using this Toyota oil .. oil has a greenish brown color so I can read the dip stick .. mobil 1 oil is very clear like a water look hard to read the oil on stick.
BillM777
