Did anyone had their issue with the propeller shaft come back? I brought mines into the dealer on 6/12 to get it replaced. 10 months after being replaced, I am starting to feel that clunk again.![]()
you sure it was replaced?Did anyone had their issue with the propeller shaft come back? I brought mines into the dealer on 6/12 to get it replaced. 10 months after being replaced, I am starting to feel that clunk again.![]()
Now, that's sounds like a good advise.Have you been lubing the new driveshaft? Makes all the difference... I feel this problem keeps occurring, even after replacement, because the new driveshafts aren't being lubricated (and neither was your original, most likely).
Pump that sucker full of grease (I mean a lot) - then remove the entire zerk fitting and move the truck back and forth a few times, hitting brakes fairly hard to allow some squat in both directions. Wipe away the excess grease that came out where the fitting was and reinstall the zerk fitting. This is the only way I figured out mine was no where near full.
I put a few more squirts of grease in every 3,000 miles or so and I have not had the problem re-occur in 13,000 miles.
The "clunk" could also be coming from gear lash in the rear differential. This could explain why some people get their drive shaft replaced and then either the clunk is still there or it "reappears" later on.
Gear lash occurs when tolerances between the gear teeth of the meshing gears increase to the point that there is "play" in the gears. So when you accelerate or let off the gas suddenly you get a clunk. It's a fairly common phenomenon in motorcycles that have a drive shaft. It happens in other vehicles as well.
If you like to take off like a comet from a stop light, you could be putting undue wear and tear on the gears in your rear differential. A lot of people don't have experience driving offroad so when they get in situations where they think they need to "punch it" they create another instance where they can be messing up the gears in their differential.
It's a problem that usually becomes obvious over time. But once the lash is there, it's there to stay or become worse unless the differential is opened up and necessary repairs are made.
Called toyota to schedule a tech to look at mine, mentioned these symptoms and this tsb, the service lady on the phone said she never heard of it! I printed it out, and will be bringing it with me. Hopefully I won't have to fight them.
I have 52k on my 2011 sr5. I need this fix before it's too late, I drive a lot...
Anything else I can do to make this easier, be more persuasive?
I have the same problem in a 2013 and Toyota isn't willing to address the problem because my model year isn't mentioned.
Hopefully the TSB will do the magic and the dealer wont give you a hard time. As of me, I drop off the truck today and found out more details to what they are going to do. They are definitely replacing the transmission and ECU and also the drive shaft which supposedly was replace last year. I hope everything turns out ok with all this replacement parts they are doing. Pray for my truck guys!
