Toyota owners seem to be a fickle group
If you cant understand why most manufacturers, especially lower end brands dont do customer orders the way expensive ones do, you need a lesson in advanced manufacturing. The price of your 4runner will go up to accommodate the changes in manufacturing flow. Toyota pioneered 5S and 6 sigma manufacturing and supply chain management. It is the reason they are successful. They can build high quality, reliable vehicles at a low because they leverage a supply chain and automation to help. Companies like Porsche and land rover rely a lot more on manual labor and artisan work. There is a benefit, it looks good and unique but it also has engrained human error. Toyota engineered that out. Go take a tour of the F150 plant in Michigan and then go to a low yield manufacturing plant like land rover. The difference are astounding. I've worked in low yield manufacturing for years, there is a reason we have more issues...
As for jeep. Their market has changed. They used to be dedicated to off roaders. Their market has shifted to college girls, soccer moms and joe blow who want a "cool" convertible. Smart on them, but they are two different market segments really. 4runner owners want to pretend they can keep up which is why all the talk. Jeep owners dont even know 4runners exist.
Sent from my SM-G965U using Tapatalk
You should go to a Toyota factory. My brother worked for a consulting engineering firm that Toyota hired to speed up the stamping die change over between models. Toyota was doing it in IIRC around 8 minutes and wanted to get down to around 3 minutes. The next closest factory was a BMW factor that took something like 5 hours to do it. They asked why Toyota needed it and the answer was - we don't care what anyone else does, we think it can be faster, so we want it faster.
The point being that Toyota does not batch manufacture its vehicles and the factories are designed to switch not only between options, but between any vehicle that the factory runs in any order. If you go to the Houston plant you'll see a red tacoma 2dr 2wd in front of a white Tundra crewmax, in front of a cement 4x4 tacoma. Toyota likely has the best production facilities in the world at customizing vehicles on the assembly line. They only build to order and only build as spec'd so there is no inventory sitting at the factory like the big3. You'll never see a factory produce a 5,000 white tundras in a row - unless there's an order for 5,000 white tundras. That's pretty different from GM or Ford.
I've been to two of Toyota's factories in Japan as well. Same thing there.
Putting the 4.6l v8 in a 4Runner would be a non-issue. The 4Runner already has IIRC 5 different frames used depending on model. They are all pretty similar, but not the same. The GX has a different frame as well that's 1" shorter in the rear. But they all share 99% of the components. And Toyota initially did sell the 5th gen with two engine options. IIRC there's something like 7 different engines in the 150 platform now coming out of the same factory. In north america we only get 2 of them and only 1 is in the 4Runner. But they're surely modular units that could go in any configuration without too much effort.
The 5AT has 6th gear internally. The transmission has the same gear train and case as the 6AT. Internally except for one clutch bell mechanism the two are literally identical down to the part numbers for every gear, bearing, and clutch including the housing. One part of the 6th gear clutch is left out in the 5AT, because it can't shift into 6th gear, so why put it in. But it really is a 6AT, that only shifts into 5 gears. The lower end valve bodies are different. Changing to the 6AT would cost effectively nothing at all. And so this is kinda where the idea that universalizing parts saves money falls apart. Toyota could reduce the transmissions to a single one - the 6AT for all 150 platforms. But it still builds a 5 speed version of the same transmission by just not using 6th gear. Why? I have a hard time explaining this one. I can't think of any reason other than just pure laziness. That's what we put in and it's what we're going to keep using...
Toyota already makes OEM gears that would work. Toyota makes 4.56 gears for the rear end already. There's an OEM part number. Toyota does not currently cut 4.56 front gears, but again - that should be a non-issue. It cuts 3.73, 3.91, and 4.30 front diff gears. The 6AT and 4.30 or 4.56 diffs would be great - even with just the v6 and 6AT.
The 5th gen was really competitive when it came out. In 2010 it was on par with comparable models. It was a pretty big deal to be able to both run the rubicon stock-ish, and then go podium finish in the Baja 1000. It literally did better in the Baja 1000 than Ford has ever finished with a Raptor and also could hustle through the Rubicon. That's pretty damn impressive for something you can also comfortably jump in for a thousand mile road trip. The times I've been down to the Rubicon it's 700 miles each way. And the 4Runner can cruise comfortably for 1400 miles round trip, and still run the trail when you're there. It's a great vehicle.
What the frustration is for me is that once you start wanting to go a bit further than stock it gets really difficult and expensive. And the changes we'd like are not rocket science, or expensive, or difficult. And they're just not happening. Nothing is happening. Toyota is just sitting doing nothing. And not just the 4Runner. The Tacoma arguably got worse with the 3rd gen. The Tundra hasn't been updated in over a decade. I'm not really sure how the Sequoia still exists. The GX is probably right where it should be - except it gets terrible mpg. And the LC200 - it's great but 13mpg? I think there are kenworths that can approach that with an empty trailer. All of those models were top of class or near it when they were introduced.
The problem isn't so much the products at introduction, but the frequency of new products. And Toyota knows it. They've spoken publicly about the failure to update their products. Especially the Lexus lineup that's out of date almost entirely across the board. And then the update to the IS is new dash vent shapes? Really Toyota - that's the great new update? Round dash vents?
When you see 6 speeds in a Yaris (the cheapest car they sell), and they won't even allow us to use the 6th gear that's already in the transmission we have - it's frustrating.
And what's more frustrating is that toyota really does build a better transmission. And a better engine. And better axles. The Toyota axle design is objectively better than the Dana 44. The differential is more compact and stronger. The drop our 3rd is sooo much better than having to build a diff in the housing. It's not really close IMO. The Aisin transmissions are better than Ford or ZF transmissions. Toyota's engines are better than comparable Chrysler or Ford engines. Toyota uses higher quality and larger size bearings in almost every scenario compared to competitors. Toyota's cold forging processes are second to none. I just really want Toyota to give a damn about the 4Runner. I don't really want a bronco. I want a modern 4Runner or land cruiser.
Honda was an ''Engineering'' Company who made Motor Vehicles.......then they just ''built Cars''.......seem to want to push the ''Green'' aspect and ignore the passion and performance they were capable of. Toyota are in the ''Just enough to get by'' mode now too. I think it is the Japanese mindset that has changed in the last 30 years. They used to push the boundaries and take pride in solving problems with analytical thinking.....now there is a defeated attitude to the society and it shows in the cars as well. They are still capable but settle in a way they never would have before. Lucky for Me, I am not too demanding and My dream truck is still in my driveway 39 years after it rolled off the lot. If Toyota doesn't step up on the next Tacoma, it will be there until I die! (well, even if they do!)
My 4runner is my first vehicle (except motorcycles) that isn't from "the big 3".
2017 SR5, it has more bells and whistles than I'm used to or that I care about.
I bought it used from a Toyota dealership. It came with aftermarket wheels and 285's. It also had a leveling spacer.
There are mods that will taylor the truck to my needs and wants, but the basic vehicle is really good.
If I lived in a city and was on pavement all the time I would have bought something different. I'm seldom on a freeway so on ramp acceleration isn't paramount for me. I live outside an unincorporated rural town in AZ with only a couple of paved roads. There are quite a few "streets" here that require ATRAC to travel.
Common complaints I see here that I'm fine with:
Headlights, power (torque), gearing, radio, seats, fuel mileage, and a few others.
Planned mods dictated by where I live:
Replace leveling spacer with appropriate lifted shock/spring, skids, replace Nfab nerfs with sliders, move spare tire from underneath.
If I want to go quick I have my street bikes. A bit tricky getting them to pavement in winter. Driving every day and exploring, the 4runner. Hardcore offroading, my quad.
Just need the right tool for the task. It's possible to drive and pull nails using a screwdriver, but you'll be complaining about it.
I love my 5th gen. I smile every time I look at it. It won't win any races, beat any jeeps offroad, get good gas mileage but it makes me smile every time i drive it.
"Jeep owners dont even know 4runners exist."
Considering the number of Jeep owners that have come up to me to talk about the 4Runner, I'd have to say your statement is downright silly and uninformed.
Maybe it's just that folks surf fishing on the Outer Banks are friendlier than wherever you are. Who knows.
A lot of them ask if the 4Runner is reliable or if I've have any trouble with it. :)
Well thought out write up and I agree. The reliability ratings of all the cars has evened out quite a bit, dare I even say it's a bit more fair? I find it also depends on who writes the articles, or more like who pays the bills.
This article puts Chevy, Buick, Mini and even Dodge ahead of lots of Japanese cars.
https://cars.usnews.com/cars-trucks/most-reliable-cars-cars-that-last-forever
1) 2020 Toyota Corolla
2) 2019 Mini Cooper
3) 2019 Mini Cooper Clubman
4) 2019 Buick LaCrosse
5) 2020 Nissan Versa
6) 2019 Chevrolet Cruze
7) 2019 Toyota Prius c
8) 2020 Buick Regal
9) 2020 Toyota Camry
10) 2020 Kia Forte
11) 2019 Kia Cadenza
12) 2020 Toyota Prius
13) 2020 Chevrolet Impala
14) 2020 Hyundai Elantra
15) 2020 Dodge Challenger
16) 2019 Toyota Yaris
17) 2019 Kia Rio
18) 2020 Toyota Prius Prime
Notably not mentioned Honda, Subaru, Ford, VW, Audi, BMW nor Tesla? Come on a freaking the ultimate rental car - Chevy Impala and Dodge anything? Seriously. OK I have some bias.
Here they ranked the 4runner 2nd from last. The quote the body on frame as an issue, but it's a reliability report?
https://cars.usnews.com/cars-trucks/the-most-and-least-reliable-suvs
In our ranking of midsize SUVs, however, the trade-offs for its off-road prowess become apparent, leading to a spot near the bottom of the list. Its truck-like, body-on-frame construction provides a ride that doesn't have the refinement of many rivals. That same construction makes the 4Runner less fuel efficient than many competitors.
I like my T4R, but I'm not a Toyota die hard. They have their good points and places to improve. But the market is changing and they will do their best to adapt. Will they do it fast enough with out ruining a good thing?
These days it's extremely difficult to get good, unbiased car reviews. Before the Internet, there were a limited number of media sources that manufacturers could use to gain attention for their products. So even though the media did rely on advertising revenue from the very same manufacturers, they had more power to remain editorially independent and fair. Today all the really experienced outlets struggle to stay financially afloat and advertisers have used this to their advantage to force reviewers to shift away from the center.
As for US News' Car Reliability rankings, no mention of Ford makes sense since they don't really have cars anymore (and Ford is on that US News' list of most reliable SUVs). But the absence of Honda is pretty hard to excuse.
Will Toyota change fast enough WITHOUT ruining a good thing? That is the million-dollar question. With combined average annual sales over the past 15 years in the 80,000 range, it's clear quite a number of consumers like the 4Runner's form factor and functionailty - even if most don't maximize it. So one can only hope Toyota will endeavor to keep the core of what makes a 4Runner what it is as it works to address changing tastes and a world hungry for better fuel economy and newer technologies.
i like my 4runner exactly the way it is.
Although I wouldn't mind toyota upgrading tech, safety, and creature comforts that do not undermine reliability, so LED lights would be a good example of that. However, even that doesn't bother me, since i can upgrade those parts by myself.
Most people these days just want to complain so they can be heard. Easiest argument to make is ignore what you have, and wish you had someone else's stuff.
Less complaint threads these days on the forums about their 4runners though. When you actually have real world problems to face, the comfort level of C vs E load tires don't seem so important anymore.
Anyways, everything is about perspective.
For what it's worth I traded a 2011 Limited for a 2020 Limited. The 2020 actually has Bluetooth that works reliably but the Entune app is already obsolete. It does have carplay, which is OK.
The TSS is sort of useless, I had a dickhead brake check me and all the TSS did was beep. If wasn't already on the brakes I would have looked at the dash to see what all the fuss was about an really tested it.
The radar cruise is pretty good. It also has heated and cooled seats, and finally seat memory. That only took 10 years.
The general audio/nav interface is "ok", but of course it's touch screen and virtually unusable while driving, because you have to look at it to do anything.
Beware, this post turned into an aimless ramble at some point, but I decided to share it anyway. Feel free to agree, disagree, add your own rant/incoheremt babble as you see fit! :cheers:
Just some observations of my time here since 2014, lurking on Tacoma forums, and recent experiences on Tundra forums...
I find it interesting that the Toyota camp is divided. On one side are the reliability loyalists that love Toyota for their proven durability, even if that means having more "dated" vehicle characteristics and longer product lifespans between major upgrades.
In the other camp are those who appreciate the reliability and high resale value, but bemoan the fact Toyota is rarely pushing the envelope and cutting edge with their product assortments.
I'm often entertained by conversations around Jeeps. For whatever reason, the 4R crowd talks about Jeeps almost as much as the Jeep crowd does. The reliability card is played religiously in every one of those discussions to justify labeling the 4R as superior. Then in the very next thread there is much wailing and gnashing of teeth about the 4R being ancient, boring, and not having all the cool gimicks, gadgetry, and doo-dads the Jeep does.
Not meaning to poke anyone in the eye here, as I love my 4R and Tundra for what they are, and I appreciate all the great advice and knowledge gained here. But you have to admit the fascination with 4R vs Jeep (and now Bronco) is... odd? Because I don't see Jeep people constantly postimg about 4R's. On one hand we love Toyota for the reliability and great resale value they provide, and on the other we seem to gripe that they're not upgraded constantly as a trendy fashion accessory with cutting edge technology or engineering that caters to our specific demands (wants).
But I have to ask, why is constant change necessary? What is so bad about a 10 year model run when the platform is solid? The automobile has been around for 120+ years, mostly in the same basic form. What can be changed yearly or bi-yearly that is truly different? We still have seats, a steering wheel, gas/brake pedals, ac/heat controls, radio, and head/tail lights. 2 or 4 doors, 4 wheels, an engine compartment and a trunk. That's pretty much it, same basic layout/proportions for most. Some manufacturers like to switch out shapes of body panels and dash layouts almost as often as I change underwear. Why? Seldom are these changes earth-shattering, they just make it look different and maybe slightly modify some trivial functionality.
I dunno, I'll stop rambling like a disgruntled old man now, I guess. Thanks for listening, if you've made it this far. :)
You've been on 3 forums in 6 years--does that mean you've driven a Tundra, Taco, and 4R in the last 6 years? Why so fickle--why the constant need for change?
Lurked on both Taco/Tundra forums for a year or so before finally deciding on the Tundra. But yeah, I went through 2 vehicles in roughly 5 years getting to the Tundra. Here's how it happened;
Had a 2010 RCSB Ram 1500, and felt the transmission was in the early stages of going bad. Only had 30k on it, so I decided long term I didn't want to deal with reliability issues. A friend of mine had a connection with a GMC dealer and helped me get a great deal on a 2015 Sierra ext. cab (I was looking at Taco's then, but didn't buy one. Probably should have). I just never really loved that truck, although it never gave me any problem. It was just meh, something was missing in the driving experience, although I can't explain exactly what. I traded it after 2 years... At the time, I was missing my old Jeep TJ that we had traded for the wife's car 4 years prior, so I got a 2017 JK Wrangler. It wasn't built as well as the TJ's were, so I became leary of owning it outside if warranty and decided to go back to a truck. Love the 4R, and decided to look at the "new" Tacoma, and also the Tundra. After crawling all over both, it was apparent the Tacoma seats were not going to work for us, so we got the Tundra.
So yeah, I'm not sure if that makes me fickle, indecisive, or foolish. Probably a little of all 3.:)
A lot of good discussion and points made in this thread - appreciate you all participating!
A couple things came to mind (actually more, but I'm sure I forgot a few already), but the main one is around putting the Lexus v8 in the 4R. Have you seen one of those GXs lately? I thought the Limited 4R was ugly, but some designer at Lexus said "You think that's ugly? Hold my beer, I'll show you ugly!" If they put the v8 in the 4R, nobody would ever buy a Lexus! They need to have something to convince buyers it's better than the lowly "working man's" 4R and worth the extra $20k.
Also, the hard core wheeling/overlanding stuff. I don't see the Japanese caring about the ability to put larger tires on a vehicle unkess they are designing a vehicle specifically to have a need for them. I could be wrong, I'm no expert on Japanese psychology. Also, I'm curious just how big the market really is for people that NEED beefed up suspension and 4x4 components for the level of wheeling they do. I know quite a few do, but enough to justify not only the R&D cost, but also the cost of potentially making the vehicle unliveable for the masses (thus cutting sales to "normal" users in favor of "niche" users?) And again, if the 4R was built to that level, would it impact LC sales?
Further, would those upgrades really appeal to the hard-core, who likely enjoy on some level building their rigs exactly how they want them? Or would it just pacify a few more of us "posers"?
[MENTION=113024]Jernik[/MENTION]
I have the Limited and it's not the best looking, but you can give it a face lift and still get the creature comfort and the AWD. See DaytonViolets Build.
Personally I spend most of my time (99.9%) on the paved roads and I'm not rock crawling the rest. With some decent tires it works fine.
They ruined the GX and LX with the "spindle grill". Remember that Lexus is the Mercedes of Japan and you need to have style and be classy. If you are doing that to it you might as well make it a unibody and save some money and weight. That will get you to your wine tasting on time.
They are design by marketing numbers not off road enthusiast. If they were designed by enthusiasts, you would pay $150K.
This Custom 2020 Toyota Land Cruiser By Slee Off-Road Is Top Notch! (Video) - The Fast Lane Truck
But even this is limited because they had to mod everything to make it fit. If it was built like that to begin with you would get more off road functionality.
To be fair, the 4R Limited would be perfect for us too. I'm just too vain and can't get past that chrome bar across the front (and the added chrome pieces on side and back). While not as hideous as I made it out to be, I like the cleaner (non-chromed) lines of the SR5 and Trail editions.
Totally agree on the Lexus grilles. Most of their lineup looks great... from the front of the hood back. However, in addition to the ugly mug out front, I think the GX looks bloated in the midsection compared to the 4R.
Being a Toyota and reliable, We do tend to forget REAL problems others have. After 5 years here in 120 degree temps, I had my first ''Failure'' on the 4Runner........the front wheelwell liners on both sides rotted and ripped loose! The HORRORS!! As I was pulling the grommets to ready for new liners a couple of Guys walking their Dogs went by and said ''Beautiful Truck, I have been wanting to get one'' I honestly replied..''Do IT!, you will LOVE IT!'' He said ''Thanks! good to know'' In the end I would buy another 4Runner in an instant if mine were stolen or wrecked.
If the Limited would be perfect for you in all ways aside from the chrome, then don't let the chrome stop you. Either get a Nightshade (for muted chrome), or just accept it for all the other positives!
I would consider the nightshade, but with our Trail paid off and only showing 49,500 on the odometer, it'll be a while before I get another one. :thumb:
Heck, I have the same mileage on my 2019, also paid off, so I get it!
I don't know, they somehow managed to make the 4th gen and GX470 coexist. I know a lot of people are jumping ship for the GX platforms and while the luxuries and V8 are definitely a plus the looks, excessive fascia, barn door and lack of aftermarket armor is off putting. I don't know if at this point I'd consider a GX platform, would rather wait for a 6th gen and 300 LC or go used 200 LC. You should see all the comments on the GXOR FB group though, they act like the GX470/460 is such a superior vehicle to the 4R. Plenty amusing since people have only been considering the GX platform over the last 2 years or so.
I do think there would be a big market for a more serious off road vehicle. The reason the 80 series LC was so popular was because it was simple, SFA, SRA, triple locked, and you could fit 35's with a 2" lift without any chopping, cutting or rubbing. You see people paying insane prices for any type of 80 series and $20-$30k for a low mileage good condition one or you can get a rebuilt Icon 4x4 80 series for $250k. Prices have only increased in the past few years. I feel like they should reintroduce the 300 LC in a similar vision, the big daddy offroader/overlander, and the 6th gen as something less capable. That's why people loved the 80 series and 3rd gens.
With that being said, would I rather have a new Bronco Badlands Sasquatch or a 5 year old 200 series LC? I'll take the 200 series any day of the week.
Yah LOL. The chrome bits are a bit much.The full off road bumper is a bit too much for me at the moment and the front end swap is a lot of work. I'm thinking I might use some plasti-dip and see if it looks better.
The 20" wheels are an interesting look too. They have a bit less roll than the 17" but they look a bit delicate. If you stuff some 285/55s on there it looks much better. If I find some local TRD Pro wheels cheap, I could be down with that.
It looks like Lexus and Honda are having and ugly contest. It's like a Nike commercial gone rouge.
Jesse1
