Toytec top plate spacers
Duke562
Hey guys anyone in SoCal either San Diego or Orange County have the hook up for installing the toytec top plate spacer for the front divers lean or able to do it I will pay for the time . Pm me if you can help
If you know anyone with even a slight amount of mechanical aptitude, they can do it in 30 min.
1. Remove wheel
2. Remove cotter pin and Tie rod bolt (tap link end with hammer to knock out)
3. Remove 3 bolts on top of shock tower
4. Remove lower shock mount bolt.
5. Slid out strut by pulling outward at the bottom...
6. Put top plate spacer on and reverse steps to re-install.
Very easy. The top 3 bolts can be a little tricky and tight. Just used a boxed end or gear wrench. If you can't get enough torque, link two wrenches together for added torque (It's an old trick that you can look up on google...)
