Now y’all got me nervous. I just bought 4 new Denso sensors and I’m getting tires installed next week. Maybe I’ll keep the old ones in for now. I do have TechStream and I took pics of all the IDs if I need to program them.
The older 5th gens can only read 4 tires.
Interesting, I have a 4th gen and it reads the spare too. I don't think it would read a second set, like snow tires, but I'm not sure. I don't have them anyway. You have a full size spare?
As it was I had the OEM sensors installed on the wheels with my snow tires and once bolted on I reset the system to read the new sensors through the dash display with control buttons on the steering wheel as outlined in the owners manual. Having plug and play snow tires was the primary reason I went with OEM.
What year did fifth gen's change to the system I have?
Yes, full sized spare on a steelie with a rubber stem.
Here’s a Screenshot from TechStream. You would think it will take a fifth sensor but it does not.
If the spare has a rubber valve instead of the aluminum one, then there's no sensor there. If the spare is on a steel wheel instead of alloy then most likely it doesn't have a sensor.
Did you try lowering tire pressure on all the tires when the indicator was flashing? If it's sitting there, engine off, key in the run position and it's flashing, lower the tire pressure to 20 psi. If it goes solid, air up that tire and it should switch to flashing. Go to the next tire and do the same thing. If the flashing doesn't stop, that's the problem sensor. Swap that tire with the spare and drive around without the suspect tire to see if the light stays out.
Was running a bunch errands this morning, maybe 10 to 12 miles of driving total. TPMS light was off to start. This gave me false hope that the problem may have "resolved" itself..Then on my way home, just about to turn into my neighborhood the light starts flashing and goes solid. I'm wondering if I just take it to Toyota whether their equipment will be able to figure it out.
