transmission temp gauge/monitoring
jreiter
I've seen a few people post up their tranny temps while towing. What are some ways to monitor transmissions temps? I wouldn't mind having a gauge for it, but I wouldn't know where to tap in. Perhaps just a sensor inline in the tranny cooler hose that goes to the radiator?
Otherwise, is this temp already monitored and available with an OBD reader?
I would consider using the ScanGuage which can be found on Amazon.com for about 150$.
Good luck
Good luck
iDriva4R has a Scangauge. He can tell you what it scans. I am not sure if our 4Runner already does tranny and oil temp. I don't think it does, but I could be wrong.
I do have a ScanGauge, but it's an older one without the Xgauge feature. I guess it's about time I trade it in for the newer ones.
I think the issue is does our computer record the tranny temps? Or do we need to tap into the line and buy an aftermarket gauge?
Does anyone know the answer - do we need to buy a tranny thermometer or does the computer record this temp and can we pull it using the scangauge?
I have the scangauge with x-gauge and no it can't read the tranny temps.
Funny thing is .....reading thru the factory repair manual I don't even think there is a external temp sensor on the a750 tranny to tap into to get a reading up to a gauge. I found the one on the a343 which is the 4 speed tranny.Maybe ,somebody else read the manual to see if I missed something here.
Also the only way to add fluid or check the fluid level is to fill it until it comes out the overfill plug hole. It does have procedure to check temps.....all it says is to put in fluid detection mode and idle speed control mode and then adjust the temp.to the specified value. It does have a cooler already as I was looking to relocate the lines.The tranny cooler is internal to the radiator I believe with lines coming out both sides on the bottom of the radiator.
One thing about the a750's is they are a very,very reliable and have been so for years.! I don't think that I have ever read about a problem with them although I'm sure there had to be some. Lot of complaints about rough shifting and the shift points but not about reliability!
After going through a few threads people were having difficulties because of their firmware. I bought my sg2 nov 2011 and it had the 4.06 firmware on it. I had no problems programming it. Hope that helps!
If you have a Garmin unit you could get this to go along with it to read it....
https://buy.garmin.com/shop/shop.do?pID=38354
I do have an OBD II reader but have not checked to see if I can read the tranny temp.
Is this the right one?
<iframe src="http://rcm.amazon.com/e/cm?t=aveshop0d-20&o=1&p=8&l=as1&asins=B000AAMY86&nou=1&ref=qf_sp_asin_til&fc1=000000&IS2=1&lt1=_blank&m=amazon&lc1=0000FF&bc1=FFFFFF&bg1=FFFFFF&f=ifr" style="width:120px;height:240px;" scrolling="no" marginwidth="0" marginheight="0" frameborder="0"></iframe>
Thats the one, needs to have the xguage capability. I bought mine about a week ago and it does work.
From the description:
The ScanGaugeII has been redesigned with expandable Add-A-Gauge (aka XGauge) technology. Add to the original 12 gauges by customizing the ScanGaugeII to monitor up to 25 more--depending on your specific vehicle's sensor design. Four gauges can be displayed simultaneously and can help determine fuel consumption rates, allowing you to adjust driving behavior and save gas. At the same time, keep an eye on coolant temperature, engine speed, and much more in real time. If there is a young driver in the house or friends borrow your car, the ScanGaugeII can record speeds of up to 158 mph and store the information for you to view later, so you will know just how fast your young driver or friend was going last night. If the unit was disconnected, you'll know: An indicator will be displayed in the trip data.
I had to get a ScanGauge!
The HP gauge is load of fun, it ain't right but it's off in the right direction -
says I'm laying down 309hp :trophy:
reviving a really old thread
Just had a pioneer 8200 NEX + Maestro RR installed and I was hoping for a transmission temp reading but it doesn't seem to read through the connections.
Has anyone been successful with this? I have a 2010
