TRD Exhaust - Available in 2020 M.Y.
Went to Starbucks for lunch.
Here’s another sound clip of how I typically drive (like an old man).
Accelerated from a stop light and ended the clip around 50mph.
I think it sounds best if you wear headphones and listen to it about 60%.
TRD Exhaust (typical driving-43 secs).m4a - Google Drive
Doesnt seem too bad. A little throaty.
Stock intake? Trd intake? Other?
I just installed a trd intake and was surprised it's a bit louder. Trd exhaust comes tomorrow so will be interested what the end outcome is.
Completely stock. Just picked up the 2020 TRDP a few days ago (Monday night).
ive heard a few complaining about drone at highway speeds. same issue ?
Can't speak for others but mine is fine. It has a very mild exhaust sound but wouldn't call it drone. Want drone, get aftermarket bolt on. Buddy spent 6 hundred on his and after he heard mine ordered the trd
Curious if the drone goes away over a few hundred miles as the exhaust breaks in and coats with carbon?
This usually happens in other exhausts, but it mellows sound. Not sure it would get rid of a drone completely =/
Picked it up from fedex today. Box was way bigger than expected. Harder to hide it in the garage than my slimline bumper! Hopefully it's not noticed before i hopefully install on Tuesday.
I like mine as well. I don’t get any drone on the highway- guess it depends on your cruising speed. I’m usually 70-75. No issues.
I actually wish it was a bit louder outside the vehicle... Inside noise is perfect for me and hasn’t pissed off any passengers, yet.
Again, it’s no 5.0 Mustang with Flowmasters, but it’s something.
Just picked up mine from the dealer and installed it. I'd say I am happy with it so far, I am wondering if there will be any change in the structure of the sound after a few hundred miles of driving.
Currently, with all my interior noises (MTs and Gobi rack) I only really hear it to a loud point when first pressing the gas and crossing over 2k rev. While are driving speeds with constant pressure it's sound is not louder than everything else going on inside. With minimal radio added in, I'd forget it was added.
So, for those that want over the top loud pipes maybe this isn't the kit for you, but if you want a factory TRD option that sounds better than stock it works just fine.
anything special with install? Any tips? I am hoping to install mine tomorrow, seems pretty straight forward if you can get the bolts off to get the last portion off.
Anyone have the TRD intake AND TRD exhaust? Ive had intakes on other cars and was a little surprised by the sound increase on acceleration with just the intake, will be interesting to see how it is with exhaust as well (I've had hondas with intakes and exhaust in the past, so have done loud before). Hoping exhaust doesnt add much more.
I helped my nephew, who is on par with Raymond Babbit most days, remove his stock exhaust without cutting it. Just used jack stands and some creative twisting and turning. It WILL come out without cutting, regardless of what some people seem to claim in other threads.
Would a couple of Rhino Ramps help? I use them now and them (with a jack stand as backup) on both rear tires or one side to get access to Fluid Film the undercarriage.
I was thinking to drop the spare and put it on the ramps and take this on myself, local dealer said maybe 2 - 2.5 hours to install!?
If I understand the directions and notes here you are reusing the exhaust gasket on the front? Should I just replace it if I'm there anyway?
You would want to use stands under the frame so the rear spings will decompress lowering the rear axle, giving you more room to work.
It was VERY straight forward, break the stock bolts and mounts and it just goes right into place. Love OEM for that.
Yes, I am using the K&M intake and the front side was always louder with the open air flow now the rear equals that out. I am sure I am getting a small HP boost but that may just be all in my head. Sounds great though.
Yep, just got done. Way easier than expected (although havent driven around yet to make sure all is well). Hardest part was getting the rear tail pipe section off and back on again. The new tailpipe section has 3 bolts and was a bit wider, so I just took off the heat shield, slipped it in, reinstalled heat shield.
First thoughts....
-it was easy
-it looks good
-you can tell at start up and idle, just a slight rumble
-conservative driving you can hear a little
-regular driving it's there on acceleration
-hard acceleration is moderately loud
-cruising speeds not too noticeable
-havent driven on highway yet.
-some pro drivers are not going to like it
-glad I didnt get the Gibson
-someone earlier said with an intake the back matches the front and that's spot on. Definitely more noticeable since I did the intake and exhaust....wife hasn't been in the car yet, shes likely to notice.
Just got it done too, pretty straight fordward but cant get 1 of the tailpipe bolt off, end up cut it into pieces lol
:lmao:
With air tools and a lift this should be a 10-15 minute job.
It's a bolt on cat back exhaust, I ran a muffler shop for a while and could put a full set of dual exhaust on most trucks in 2 hours.
That included bending the pipe.
My Borla definitely changed tone a bit after breaking in for a couple hundred miles, it's pretty much the same with any exhaust
kimyuseung77
