TRD Pro parts
Here is the pdf instructions for the rack assy....
It has the part #'s for the rear only as well....I knew I had them somewhere!
Got these babies in today..... Can't wait for Saturday.
Posting for comparison...
Hard to tell any difference in the plate other than cutout.
Looks like the bolts are in the same place.
Looks like they used different sized/style lettering for the "TRD" logo. Look at the "R" on both pics.
Maybe they used SR5 non KDSS Radiator Support Brackets.... oh, should be able to purchase those from TOYOTA.
Thanks for using my image too! :D
Sup Saker! I need the trim piece for the top of TRDP front skid, where the heck did you find that?
Thanks in advance!
Thanks in advance!
[MENTION=119618]Hook Em' Horns![/MENTION],
Hey man, that came OEM on my SR5.
Just look it up or have dealer look it up for my description in my Sig!
Then just trim it to fit so it won't have to be removed when you need to drop the skid, follow my write up on size/style bolts to use!
Hope this helps
. : : EDITED : : .
Here is the final product.....
Hope this helps
. : : EDITED : : .
Thanks again, bud! I already have so much to do, so adding this to 'the list' right behind rear diff breather.. Hah
Hope this helps
. : : EDITED : : .
Wait, so mine likely had one until they installed the TRD skid pre-sale? If so, then they gank'd my part, no?..
Thanks, Saker! So just that and the new bolts mentioned earlier?
Yep, M6 X 1.0 with flat washers like in the photo.
Buy some fender washers that the bolt is just oversized, drill the washer out so the bolt fits, you will have to fit test the filler piece to your liking, but once it is finished and up, it will not have to be removed when removing and replacing the skid plate for oils changes etc...
I cut the least amount as possible to get as much coverage as possible, but enough so it caused no interference...if I made myself clear....
Yes! :flame::infidel::sorry:
:llama: . . . . . . . . . . . :sniper:
Ah nah, hell nah!!
1) Called my local Toyota dealer's parts dept. and confirmed they do come stock on SR5s.
2) Asked to be transferred to the Sales Manager...
3) Explained situation...
Him: "Whatcha want me to do, buy this part for you, or what?"
Me: "Yep."
Him: "Come on down and I'll write you up a ticket to take over to the parts dept."
:girl:
TRD Rear Handle Panel + Blackout Kit
Swapped the rear hatch handle panel out for the TRD/TE panel (black), and then applied the blackout kit.
Next up, rear bumper garnish...
DJNutshell
