TRD Skid Plate Mounted w/ Studs 2010-2024
Sounds like the dealer owes you a new piece. What was their proposed solution?
They never gave me one. Their only solution was to cut off the loose bolt that was screwed into the nut. So I brought it back to them and they just cut the bolt off and said tey took care of it. When I saw it, I realized they just did that and there's no bolt in that right front hole. So now the plate is just mounted using three bolts. It ain't going anywhere, but still. Really annoyed by it.
Pretty simple for a competent welder.
With a new nut, chamfer the outer edge a bit.
Drill a hole so the nut will pass thru.
Countersink the hole slightly.
Hold new nut in hole using a minimum 2"+ bolt threaded into nut.
With the new nut flush with the frame member, using a TIG welder, tack the nut to the frame member on the outside.
Remove bolt carefully, continue to tack in more spots and/or finish weld
When cooled off, chase thread with a tap if needed.
With a good weld, there should be no grinding flush needed.
20 minute task, max.
Appreciate this Seatia! I'll look into it.
There are many grades of Loctite red, some require heat to remove, others dont. Blue is ok ive used it for years on various parts. I use to use alot of Green in specialty transmissions as well. This chart only has a few of their range but you get the idea. I think blue for most parts with red for specialty stuff
Thanks for taking the time to write this up and post it
I do have one question why did you use Stainless Belleville Washers (WB16SS - Stainless Belleville Washer) and not the washers for a 10 mm bolt?
Matt
Matt
It was the choice at the time, one could use a regular SS flat washer, or as I chose to do all black coated hardware (it blends in with the black skid)
did an oil change at 7500 miles interval, I have a the trd skid plate and the front push nut bolt retainer was broken from a previous oil change. It wasn't too difficult to line that up. One bolt in the rear wouldn't go in all the way, so i had to rethread but it works now.
Oil change took about 15 minutes besides the rethreading.
Did you change over to using studs instead of the bolts?
not yet but its crossed mind again, I have this forum bookmarked for reference along with the replacement retaining bolt. Its maybe twice a year if that I'll need to remove the skid plate for service.
I got an even better ideA. Run the trd pro skid plates with an oil change door and call it a day.
Takes me 5 min to do an oil change….
You will be very surprised how easily dropping and re installing your skid plate will be with studs & nuts!
leolediola
