TreadWright coupon
Arn24
I don't know anything about this coupon other than it worked for me today. The code is FIFTHFREE. I think it just takes 20% off everything when you have 5 tires in your cart, as I think it knocked some shipping off as well.
I bought 5 265/75-16 Wardens (D) for $510 shipped.
Anyone looking for the Warden is a C is probably SOL, they didn't know when they would be getting any more C carcasses. Guess they're hard to come by.
Good luck.
I got an email from them. 1/2 off shipping on all tire orders with code: shipping50 or buy 4 get the fifth free with code: fifthfree (note, be sure to enter 5 tires in your cart)
Got all 5!
This is so tempting, I could get 5 Guard Dog's for the price of 2 Duratrac's at the size I want.. Has anyone had experience with durability or the Kedge Grip option?
Appears to me that the discount code only works when purchasing 5 tires. Still a good deal. Kinda wish I would have thought about this route before buying new tires in March.
Just FYI. I emailed them and asked about airing down for wheeling purposes. If you air the tires down you will void the warranty.
At this price I could get a second set of tires. Kinda always wanted an AT tire for when i'm not wheeling so my Maxxis Bighorns don't get chewed up on the road.
Compare the weight.
You'll probably spend those last two tires worth of gas with the difference.
That's coming from somebody who has the Guard Dogs in 33".
Kedge Grip holds up well. I'm at 30,000KM (on the nose) and it's wearing pretty well. I forget new measurement so measuring now isn't much use. If you run them right down I can see 60-750000 km. By 60 you won't be doing much offroad I don't think.
They suck in the winter. Soft snow, firm snow, ice, everything. Bad. I can't say how they are compared to other mud terrains, but they aren't good.
They are also stiff. Mine are D rated and very rough. Running low pressures trying to soften the ride. 30ish PSI. In the winter I drop it down to 27/28 for grip.
Would I buy again?
No.
Compare the weight.
Would I buy again?
No.
That's all it took to change my mind. Living in Montana I need a solid tire that can perform in the winter. I used to have an Xterra in which I ran some 33'' ProComp M/T's and they were the absolute WORST here. Guess I'll be sticking with the Duratracs
Personally I think thats a good decision. I live just above you in Calgary, Alberta. We probably have similar winter conditions. I only went with Treadwright beacuse I felt I had to give them a try. I like that they were recycling tires and saved me money. I'm also not the biggest fan of the way the Duratrac looks, but that shouldn't mean much.
The only "good" thing I can say about these wheels in winter are they can be somewhat predictable. I drive slow and cautiously and it's not really an issue but I have gone around quite a few mountain pass corners sideways, not exactly as I intended to. Just have to be quick to react and drive accordingly.
When going to one of our shooting locations in the winter we have to climb a moderately steep hill. One with 4-12" of snow with a bit of a crust. I was the vehicle who had the most trouble getting up and the only one with a rear locker. Hell, a stock tacoma on stock wheels beat me up the hill.. Brutal.
I understand these aren't snow tires, but if you think performance improves in the dry and warm, you're wrong. They are loud, which I don't mind. I constantly have balance issues and they are balanced properly as per their instructions. The last two times I've went into the shop and watched the tech do it. I need balancing again. The weight required is rediculous.
I've had to replace one tire because it started making a "ticking" noise that turned into a slapping noise at 3000kms. Of course they replaced it at no charge, but they don't cover installing and balancing (which gets expensive in Canada (80-100$).
Whenever I hear "good return policy" or "no hassle replacements" it usually means bad quality control. I believe this holds true for Treadwright.
I'd only buy these tires for a trail rig only. One that doesn't see winter use. Probably do reasonably well in places like Moab, Colorado during the summer, etc.
I'm now stuck with the wheels till they are worn. I can't sell them to others knowing how bad they are even if they have decent tread left. Next set of wheels will be "new".
You'll enjoy the tires, and dont fret about winter driving. I have the same tires as you besides being load E. My traction in the winter was awesome, never went into 4wd and never lost traction. Ice is a little different because its full grade truck rubber and not a softer compound, every car is subject to ice tho.
My friends with the guard dogs have issues in the winter, less tread contact and hard rubber does that.
I am still getting 17/19 mpg and I have had mine for 10k miles and they still look brand new.
