trouble replacing springs...please help
jarnld
So Im trying to replace my stock springs with some Moogs just to get rid of the sagging rear. Im not expecting any lift.
I just jacked up my runner and tried to pull out the springs and cant get them out. Is there some trick to this or is my jack just not lifting the truck high enough??
mitaylor137 said:
Im going to be replaceing mine soon and wanted to know what problems you encountered? 94 SR5
One problem I ran into was reattaching the lateral control rod. It took a while but I finally got it seated.
FYI: I had planned on replacing the rear shocks anyway and while attempting to remove them I completely snapped off the top bolts for each shock.
I replaced the springs with MOOG as recommended by an online store. I wish they had just a little more lift. Here's an after picture.
Are you going to let US know what the answer was?? Or at least a link to where you found it??
You should be able to get the Moog springs from most auto parts outlets.
I believe the p/n for a 2nd gen runner rear coils is CC255, but don't quote me on that.
patnewton
