Troubled rebuild--HELP!!
mike_arch0
I recently tore apart a 1991 4runner 3.0l 3vze to do the head gaskets and a valve job. Got the valve job finished and reassembled the engine most the way. I ran into a problem when trying to to the compression test, I have zero compression on the whole right side!?! I cranked the head bolts to spec and took my time to make sure everything was correct. I poured a little oil in the spark plug hole to test rings and still zero. Is this the gasket???? Any help would be appreciated. Thanks
EnviroHokie
