True Transformer
Daddy
Taking a 2003 SR5 that has a chopped suspension and low profile wheels to a higher level...
Starting tomorrow
Stage I:party::party::roadkill:
Fox Shocks 985-02-002 Front Coil Overs
Foxshocks 980-24-679 rear shocks
Old Man Emu 2895 Rear Coil Springs
Energy Suspension 83129R Rear Control Arm Bushings
Energy Suspension 85136R Rear Sway Bar Bushing
Energy Suspension 8.3128R Control Arm Bushing Set Red Front Polyurethane
EBC Brakes GD7237 Front Brake Rotors
EBC Brakes DP61657 Front Brake Pads
EBC Brakes GD7161 Rear Brake Rotors
EBC Brakes DP6993 Rear Brake Pads
Magnaflow Performance 15781 Exhaust System
K&N Cold Air Intake
17x9-Black-Fuel-Formula-D559-6x5-5-12-Rims
265-65-17-Nitto Terra Grappler 2 Tires
Stage II
Will be the electronics & interior - to include but not limited to...
A new sound system
New clear lens for headlights, fog lights and directional
LED lights for both inside and outside of vehicle
PIAA ION Yellow fog lights mounted on a bull bar
New side rails
Possible CB radio
ANY AND ALL ADVICE IS REQUESTED _ MANY THANKS !
You should probably add new cv axles or boot rebuilds to the list. Of they aren't currently leaking, they will be shortly after lifting a 12 year old suv. You're also gonna need extended end links if you plan to keep your sway bars. And extended rear brake lines probably wouldn't be a bad idea. New front bump stops as well (since the ones on there now are likely shot from it being lowered). Good luck. That's a lot of coin to dump into a 12 year old suv.
I'm basically doing the same thing to an 03 v8 sport, but I'm going the FJ spring and adjustable bilstein route.
Already replaced the sway bar bushings and links. Next will be cv boots, then ball joints and control arms, then install the new springs and such. I have to slowly price it together so my wife doesn't kill me for buying it all.
Hey Nate,
Thanks for the reply ! The Runner only has 84K on her, It was either buy a new vehicle or put a couple of grand into this inherited Toy. Bumper stops definitely need to be replaced. Need to take off boots and inspect - before committing to C/V replacement. This is my first Toy suspension rebuild and I spoke to several Toyota owners (Tacoma and Tundra) that had shops do their work and they said there was no need to replace the CVs - Said that any thing under 3" did not need the extensions. Got new brake lines - Just in case.
Before the tear down
Springs were cut then spacers were added - What was my nephew thinking ??? My turn ! Gonna do it the right way !!
Your nephew hangs out with the wrong crowd. Bring him over here so he can see what a 4Runner is supposed to look like.
Young ones do before thinking - I'm thinking what I have to do - let out the beast within. Pictures will be posted after I tame this animal...
Build on hold...
Until I receive the tires and rims - I cannot proceed with the build. I will probably replace the water pump in the mean time - it is starting to "whir". Well good news - Water pump is fine - Tensioner bearing was making the noise. Whew !!!
chasebradshaw
