Tundra Coil lift
Monroe Aftermarket?
I'm looking at getting the Monroe Tundra setup for my 02 4Runner. I understand what everyone is saying about the color code. My question is, how can I tell whether the setup I'm looking at will work or not? Here is a link to it, in case that will help you answer my question:
2000-2006 Toyota Tundra Strut and Coil Spring Assembly - Suspension - Monroe, Front Right 00-06 Tundra Strut and Coil Spring Assembly - 8199-07167079 - PartsGeek
So you know what I'm trying to do, I'm putting '99 tall springs on the back, and I want as LITTLE lift as possible on the front.
Thank you!
Make sure that you get the color code (paint dots on the coils), Tundra TRD Coils. Left, 48131-AF100 (Yellow/Yellow). Right, 48131-AF090 (Blue/Yellow)
The TRD coils fit:
4wd, access cab, w/off road pkg. 2000 - 2002
2wd Access cab 2003 - 2004
4wd Access cab Left 2003 - 2004
I know this is an old thread but i have to give props to LITERALLY the only place on the entire internet with this information.
Just picked up mine from car-part with this link:
Search Results
Came from a 2001 4wd, access cab, w/off road pkg.
For anyone looking for a more readily available coil than the Tundra coils, I am running 2007 Tacoma TRD Double Cab Short Bed springs on Tundra Bilstein 5100's on my Tacoma.
Rides great, soaks up the bumps just as well as the YY/YB's I ran on the 4Runner. Mine are set on perch #2 and netted 2.25"ish of lift on my Tacoma with no extra weight. 3rd perch should be right around 3" on a 3rd gen with no weight.
This is a great alternative because I can get on Craigslist and 9 times out of 10 find a set of these coils for 100$ or less.
Sent from my Z981 using Tapatalk
This would be great. Right now you can't find any new TRD Tundra Coils for less than $170 and most salvage coils are at $125 or more.
Anyone else know if this would be ok with our 3rd Gen? I'm trying to get about 2 inches of lift. Could I do the first perch on this one? I already bought the Bilstein 5100's because I found a great deal, so I'm trying to find an alternative coil to use with those that will achieve around 2"
Side Note: Do you happen to have these part numbers readily available?
Just put some purple/purple and purple/red coils and struts on mine off a 05 Tundra quad cab. Was so torn up I couldn't get any other details off it but I got my fronts plus top hats for under $100 so I'm happy.
2018 tundra struts
I have a set of 2018 tundra struts at the shop and am curious if they will fit my 99 limited. Any help Is appreciated.
Without knowing much else besides what google images can show me I’m going to say no. The bottom eyelet of the shock looks like the wrong size and the top hat is a 4 stud rather than a 3 stud
2001ATL
