Tundra springs in front, 906's in the rear?
Thought I would revive this thread instead of posting ANOTHER coil thread.
I'm wondering if I can use a oe replacement tundra coil from Napa for the front? I understand I need to re-use my top hat for the coils.
Then I was thinking 890 in the back. Should be a good set-up?
My first lift was TRD coils in front on Bilstein HDs (which would be the same as 5100 on the bottom) and OME 890s. Tires are the stock size 265/70-16. The coils are new and have not settled.
P5120026.jpg~original
P5120026-1.jpg~original
Hey just wondering how much lift did you get on the front? I'm doing the bilsteins for the front stock. Full front assembly from a TRD tundra 06, wondering how much lift this gave you and did you have to switch out the top plates? Thanks!
You should still net ~2" of lift since it's the spring that dictates height. The perch location of an OEM Tundra strut and a Tundra 5100 may have a little variance between them, but shouldn't be noticeable.
You'll use your factory top plate, but you'll want to use the rubber isolator from the Tundra plate.
charlesz
