Turn signal and 4 way flasher problem.
CaleWVU
Turn signals went out as did my 4way flasher/ emergency lights. Replaced the flasher, didnt help. Checked the fuses, didnt help. My highbeam switch works, dont know how much that is worth. Im going to check the bulbs as i have read to do. Any suggestions?
I searched but didnt find enough answers....
First sir, youre dumb....check your 4way flasher button to make sure the cable didnt come loose since it wasnt plugged in ALL the way from when you had the dash off....
Long story short, the cable top my emergency light came loose and disabled the turn signals. it must be a loop. hope this helps anyone who needs it.
I had this same problem yesterday. I took apart my dash to replace lights in my climate control unit the night before and then my hazards and turns signals stopped working. Took everything back apart and found that the connection in to the hazard button was loose.
Other people have had this issue when getting vehicles back from car stereo installers/etc.
To make this a bit easier to find when searching I'm going to dump some keywords:
blinkers stopped working hazards hazard flashing turn signals stereo radio install removed dash
