Turn signal doesn't work but clicks.
4RunnerRedondo
Left turn signal is fine. Right turn signal clicks, but the dash light and exterior lights stay off too. I changed the bulbs even though I thought they were good just to eliminate it. Anyone know what else could be broken here? :sobbing:
If positioning the switch changes what it does, yes it has failed.
Agree. Does Hazard Switch work on that side on front and rear? If they do, a blinker failure on one side (front and rear) pretty much has to be the switch.
This is a 2002, but I'd guess 2001 is similar, if not identical:
Turn Signal switch purchase
I saw a couple that has fog light switches on ebay, would this work? I don't have fogs but I think it's prewired if it helps.
I finally from the local jyard! It works. Now the only problem is I don't know how to use a working signal switch properly. I still push it back a touch. Habits habits! :smash:
MikeV5280
