Tyler James Inc's Ultimate '01 SR5
Those prices are very good! I've never used my Clutch Cancel switch ever in 17 years of owner ship. :becky: Whats it for again? LOL
Serious?! Man, I love having the cancel button on my Toyotas!
They are drive by wire. That cable is a fail safe of sorts in case the drive by wire system goes out, it allows you to open the butterfly valve a little bit so you can limp home.
Yeah, that's what I've heard. Maybe my '01 is the exception. Go disconnect your throttle cable at the TB, and take a video of it moving without the cable. My throttle cable opens my butterfly 100%. I can't speak for all '01/'02, only the one I have currently in my possession.
You're an animal!
Haha why thank you [emoji1598]
Nice to know, that was my biggest concern with taking mine into the Mexico desert, what if the clutch system dies. I had a Cherokee which lost the master cylinder or something. I had to drive it around town without a clutch. Downtown traffic. :fun:
We are talking about the throttle body, not the clutch. There is no clutch cable that I know of.
Serious?! Man, I love having the cancel button on my Toyotas!Yeah, that's what I've heard. Maybe my '01 is the exception. Go disconnect your throttle cable at the TB, and take a video of it moving without the cable. My throttle cable opens my butterfly 100%. I can't speak for all '01/'02, only the one I have currently in my possession.
Well hot damn, you're right! Pulled the cable off and it idled, but the pedal did nothing. Glad you just taught me that! Makes me wonder if there is some sort of adjustment that us 01-02 guys can do to take some slack out of the cable. Or maybe both of us just have defective 01s haha
It was my understanding that the only cable eliminated in the 01/02 years was the transmission line pressure governor.
that engine bay is beautiful! nice job! question: with the trim-shine, do you have to rub it on after you apply it? or do you just spray it on and you're good to go?
Yeah, I'm not sure where the mis-information is coming from on that. You're not the first knowledgeable member to tell me the cable is only for back-up, and doesn't open it 100%.
Thank you! To be honest, it just depends how I'm feeling that day. I normally just leave it though; I've only wiped the excess once or twice.
Not quite- the cruise went to a motor-controlled unit on the back of the TB. The only cable on the '01/'02 is the throttle pedal cable.
Sub'd again to your build. Love the OEM+ and how clean you keep it. I've got an '01 Limited in Thunder Cloud - too bad anthracite is my favorite color runner. Would've traded you :p
Thanks man! It is a very bitter-sweet. I will be sad to see the Anthracite drive off, that's for sure.
Excited about losing the body cladding.
Bummed about losing the locker.
Excited about it being 4yrs newer.
Bummed about losing the Anthracite.
Excited about finally getting a manual swapped in.
Excited for a new project.
Excited for a new color I also really like.
I guess the pros outweigh the cons. Haha
PS,
Whoever said '01/02 are drive/throttle by wire are sorely mistaken. The pedal has zero electronics; only a cable attached. There is a motor on the back of the TB, but that has to be only for cruise control.
'01/'02 are NOT drive by wire.
That's an interesting discovery. I've read that it was a drive by wire but never really looked into the details of it. It's real cool reading through your manual swap progress. Keep up the good work!
Thanks a lot man. Been super busy getting the '97 in tip-top shape to sell- well, and life- but I'm hoping to get the auto pulled this weekend! [emoji1598]
Thindercloud and Anthracite.... mmmm mmm love it!
Throw in a Sunfire Red Pearl, Stellar Blue Pearl, and Golden Pearl- and all my 3rd gen 4Runner color dreams will have come true [emoji7]
What wheels are those that look like volk te37?
Level 8 MK6
You can get a new one! Easy to find with the 4.3 gearing from the automatic. Except I already cleaned Oregon out of locker axles...
[emoji1360]
man, I liked your old runner and bummed its gone but super excited to see where you take this one.
Thanks man! I'm with you all the way on that on.
Baby steps
Lots of careful steps went in to making sure I got the holes perfect- and I totally nailed it [emoji1598]
I even made a master cyl gasket from scratch-
Taped it to the firewall, and held the master up to it. Adjusted the template till it was clocked right-
This weekend's progress SHOULD include pulling the auto, and maybe even some engine harness wiring... [emoji51]
It would be REALLY sweet if the '97 sells too. [emoji1374]
Looking good!
You mentioned Trac/ABS module was in the way of clutch pedal, what was your cure for that?
I'm not familar with Trac/VSC paired with manual trans, you going to add on/off switches to control Trac/VSC or let it control you?
Thanks [MENTION=142122]96RedRunner[/MENTION]!
As far as the ABS/VCS/TRAC goes- I really don't know. I'm not familiar enough with the system to say it can't be retained with a manual, but I've been told the manual Tacomas were not equipped. That being said, I think I could really benefit from TRAC, since I now have open diffs [emoji19]
I don't know if my speedo will even work without the ABS/VSC computer plugged in, or if anything else will be haywire. I can find a spot to tuck it up there easily enough though.
I do have the VSS wiring on the '03 Tacoma harness I got, so I could definitely swap to a VSS operated speedo instead of it running off the ABS sensors. I still need to ask how much for the VSS off the same '03.
Got the "AWD" tcase pulled last night. Trying to get the trans pulled now. The front diff is really in the way of getting to the dust cover and flexplate bolts.
Surprisingly, everything goes extremely well when I'm drinking beer. Probably the smoothest trans pull I've experienced to date(not that there are a whole bunch, but a few). Definitely spent a little time getting the stupid dust cover off, but other than that, it went great [emoji1360][emoji1598]
Don't see too many clutch MCs next to that clusterfck of a booster/ABS, do you?
For anyone following for info on an 01/02 manual swap: it's nothing special [emoji1360]
In case anyone was wondering- I hate this grill!
I'll def be using the '99/'00 grill I had gotten for the '97 [emoji1360]
I would love it if it were color-matched, and I wouldn't hate it if it was in good shape. But it's just trash. The '00 grill will be painted Thunder Cloud, obviously.
I don't know if my speedo will even work without the ABS/VSC computer plugged in, .
I puchased my 01 Feb 17, with a bad Trac/ABS module, along with a few other issues. I got it cheeaaap because of that. The speedo and odo does not work with a bad module. One of the syptoms along with idiot lights. I would say it would be the same in your case not using it.
If tacomas didn't use it there should be a OEM work around, You can do it!!
I'm wit ya on the grill mine looks just like it, shitty. Maybe a semi satoshi i'm gona play with it. Along with never have liked fat lip bumper. Have owned it 3 months, spent 2 months giving it a 200k overhaul under hood and bottom side.
