uneven tire wear on the back tires
Gecko123
I'm getting uneven tire wear on the two back tires. The rear driver side tire has less wear on the outside. The rear passenger tire has less wear on the inside.
Is it possible to align rear wheels on 4runners?
The rear is not adjustable with mechanical means. The only way to adjust it would be to bend something or cut and weld. Has it been in an accident? That is a very odd wear pattern. Have the tires always been on the rear? Do you spend your time making only right turns (j/k)? I would take it a shop to have the aligment checked. That will give you an idea of where the problem may be. I would guess it could be bad tires. That is the only possibility if the alignment is good. Post some pics and measure the tread taking several readings across the tire.
leolediola
