UPDATE: 4Runner Emergency Response with pic goodness
Came across this thread and figured you may be of assistance.
I am new to radios and have a CB, but was wondering if I need a license to operate this type of radio?
BaoFeng BF-F8HP (UV-5R 3rd Gen) 8-Watt Dual Band Two-Way Radio (136-174MHz VHF & 400-520MHz UHF)
Any feedback would be appreciated.
- Mike
For the CB, no.
For the BF, you need an Amateur radio license.
mgosts,
You're going to learn all this as you study, but there's several factors that determine whether you are allowed to operate (transmit) on a particular frequency legally.
  1. Does your radio have any necessary type-certified for operating on the frequency?
  2. Do you have any necessary license to operate on the frequency?
  3. Are you using a permissible transmission mode on the frequency? (I'm not going to worry about this in this post, but just keep it in mind.)
The radio you've listed (BaoFeng BF-F8HP) doesn't, to my knowledge, have any special type certification. That's fine for amateur radio bands - no certifications are needed there, BUT you do need a license that permits the transmission you are about to make.
(A warning: amateur radio operators are pretty good at policing themselves, and some of them are very good at tracking down people who are not doing the right thing. Part of the reason for this, is that the FCC has said that as long as the hams police themselves effectively, the FCC will not assume the role of "Bad cop". None of the hams want that, so they tend to smack down people who might bring additional FCC scrutiny to the local ham bands.)
However this doesn't mean that you can legally transmit on any frequency that the radio is capable of transmitting on.
For example: FRS radio services are in the 460MHz range - which this radio can transmit on. You don't need a license to use these frequencies, BUT this radio is not approved to use these frequencies. If you are caught using them :police:, you could be subject to a large fine.
Another example: There are many public safety channels around 150MHz. To operate on these frequencies, you need a radio that is type certified for part 90 use (which the BaoFeng is not), AND you need to be transmitting with a valid license. So you, with a BaoFeng and an Amateur Radio license, would not be permitted to transmit on these frequencies*. If you are caught transmitting without either of these things :police:, you could be subject to a large fine. (There's a pattern here . . .)
So that's a start. It sounds like you are already gearing up to take the test, which is awesome! Amateur radio is a ton of fun. I come at it from the public safety side, but lots of folks do it just to learn about radio or to talk to like-minded folks. Best of luck!
*There's exceptions to many rules. Just make sure you know what the rules are, and what the permitted exceptions are before you go breaking them! :cell:
delislerebecca
