Nice work, really like the hood and web metal work! I bet those amps have more power than our 3.4's
Thanks! Ha! Yeah, the Alpine amps have a little blue led light on them and at night you can see it glowing from under the seat. I tell people it is a Flux Capacitor. Thanks again!
Nice, Steve... It's the small touches that make these rigs "ours". Do you have any pics from when you re-worked your tire carrier to sit closer to the rig? I'd be interested in seeing those because I'm doing some brainstorming on re-working my CBI carrier.
Thanks Nick! I dug up a few pics but don't have too many. This is how it looked when I picked it up. I knew right away I would be changing it.
I don't mind customizing to my likes. In hindsight I should have been more detailed when I ordered the bumper. This was my first bumper purchase, and as with everything, a learning experience.
I cut off the mounting plate (sorry no pics of that). I shortened about 6" of the 2x2 square tube and played with the angle to match the body line. With the plate cut off, I simply rested the tire on the stubby 2x2, angled the tire to match the body line, then scribed a cut line onto the tube.
I left a little bit of room in case I end up with different rims, wider tires, and to make sure it doesn't contact the tailgate with vibration, or while closing.
I later went back and added some additional gussets between the plate and tube. I cut out these little biscuits from 1/4" plate
Welded them top and bottom of mount:
Hopefully that helps. I am much happier with it now, and it is much more solid than before.
