USB Mod: Center Console Switch Blank
Ya'll might want to check this out. I know your 4th gens and all, but this is a pretty clean way to go.
http://www.toyota-4runner.org/3rd-gen-t4rs/132944-dual-usb-port-installed-place-cigarette-lighter-3rd-gen.html
I used one of these kits on my center console dead panel. Turned out pretty good but kinda bulky looking... I use to work at a shop so I got the part for like $11.00...
Pac-Audio.com Product Details | iPod Integration for your car and More by Pac-Audio - Connecting you to the future
This link below will give you an idea of the size of the adapter kit
20121204_164832 | Flickr - Photo Sharing!
Hey, I just bought one of these kits. Any tips on installing? Did you just use a drill with a large bit to make a round hole in the dead switch?
That looks great! Would I need anything else to get this to work? I have no electrical knowledge whatsoever. Is it as simple as pulling out the spare socket, finding a wire under there and plugging this new device into it?
There's not a connector to simply plug this into; you'd have to splice 12V and find a ground location. Finding where to tap in will depend on 1) where you want to put it, and 2) whether or not you want full-time 12V or ignition on 12V.
I installed a 2-USB (1 charge, 1 audio) port in the center console, and a 12V/Voltmeter port over near the AUTO LSD button on the dash. Both are on full time; instead of tapping an existing wire, I wired a fusebox from the battery so that I could add accessories down the road if desired.
Damn, that definitely sounds beyond my expertise. I didn't understand half of that. Appreciate the advice regardless.
I bought two of these USB ports so I wouldn't have to use my 12V outlet.
http://www.amazon.com/gp/product/B0...ocker Style&qid=1444422090&ref_=sr_1_1&sr=8-1
It's the nicest looking one I could find that would fit into a blank switch location. I don't want to drill holes on the interior if at all possible. I also have the dirty parts updated dual battery switch in another blank switch spot I next to the center diff lock switch.
I'm trying to find a good location for my projecta dual battery voltage monitor.
http://www.projecta.com.au/Products/PowerManagement/DualBatteryVoltMeter.aspx
Does anyone know of a current/amperage monitor so you can monitor your alternator output? I've found some homemade Chinese junk, but I'm looking for something accurate and well made.
Fluke is the way to go if you want quality handheld test equipment. It looks like meters that do DC current are expensive.
Fluke 376 True RMS AC/DC Clamp Meter with iFlex: Multi Testers: Amazon.com: Home Improvement
There are cheaper meters of a similar style that might work, but make sure it can do DC. If you want something you can install semi-permanently, I don't know about that.
Application Error
Do you have a write-up of how you installed those plug ins? I just purchased this one (http://www.amazon.com/gp/product/B010T3CR8A?psc=1&redirect=true&ref_=oh_aui_detailpage_o00_s00) and cant find a thread with instructions.
