Using these for a potential mod... can you guess?
Yeah shift knob stuff. Want to use the pineapple for the main shift knob and the baseball for the 4wd. I have an engraver I'm going to use tomorrow to etch the baseball naid.
Problem is the 4wd bolt head is about double the size of the transmission shifter. Have to source some different stuff to mount it.
to each their own.... seems more of a mod for a '97 turbo civic drivin by a asian with a blonde mohawk lol.
That seems like a very insightful answer to the OP's question.
Its people like you that ruin forums and blogs. If you cant contribute any positive answers to what the OP is asking simply do not post. it takes far more time and energy to post a sarcastic dick comment than it does to keep it to your self.
I'd actually love to see them as valve stem caps.
Too big and heavy unfortunately. Maybe if I can find smaller ones.
I still like my idea of chucking them at Prius drivers... but I guess they'd be okay for shift knobs...
Weight is the biggest issue with these. I'm worried it will pop out of gear. The "baseball" frags are standard issue grenades. We had them in 'stan and they look light but they're not.
Plan is to cut 3/4-1 inch off the shifter and rethread it to stock M8-1.25 them weld on a long thread nut on the inside attached to the initiator/spoon. Then some sort of hose will go on the inside of the demilled hole to create a good tight fit with no rattle...
If I remember correctly someone on the FJ forum has done this. You might check over there.
The M67 just doesn't look very grenade-y like the Mk2.
Also I agree that these could pop your truck into N because of the weight.
you should hand one of those to a cop when he/she busts you for speeding and they ask you for your licence, registration and insurance.
