I just put Valvoline Maxlife ATF in my '98
Hey all, here's my story.
I picked up a '98 SR5 4WD automatic late last year with a broken transmission dipstick. After changing everything except the transmission fluid, it was still sluggish on the get up and go.
I ended up dropping the pan after draining coffee like fluid out of it.
Couldn't get the broken piece out of the pan --- ended up getting a new pan.
Anyhow, I went with Valvoline Maxlife ATF in mine. I measured out a little over 6qts from what drained over the time I had the pan off. While I was there I replaced the transmission filter.
(see YouTube)
Poured in the equivalent amount of Valvoline Maxlife ATF, and took her for a spin. Immediately noticed a difference in pickup, although it was probably related to the new transmission filter.
At this point I knew I was about 50/50 old coffee fluid and new Valvoline, so after warming it up I drained it again. Got about 3qts of purplish fluid out. Refilled with equivalent Valvoline. Started up, took her for another spin, shifted through all the gears manually, and measured the fluid. Was showing quite low, and ended up taking another 3/4s of a quart before got up in the hot range.
I now how have 2 new quarts left from my original 12 that I was planning on putting in, so I ordered another 2 quarts. After putting some mileage on to work the gunk out I'll drain and refill again.
I went with Valvoline Maxlife ATF in mine because Timmy the Toolman recommends it AND my master toyota mechanic uncle who trains the techs at dealers recommended it.
My '98 (now) runs like I expected it to when I got it ... like a V6 instead of a 4-banger. But again that may be because of the transmission filter...
EDIT: 231k miles on it. I have no idea if the transmission fluid was ever changed or not. If I was to do it all again, and I had the funds, I'd go for Royal Purple instead of Valvoline. Seems to be higher quality stuff.
(see YouTube)
