VSC TRAC LIGHTS ON IN 2WD ON 4wd limited 2005
Joshks22
Today i was doing an oil change and exploring options of disabling my traction control in 2wd. I HAVE NO FRONT SWAY BAR,and when i make some hard turns tcs comes on and brakes whichever front wheel the car is leaning into.i kno someones gonna say its an SUV and it shuldnt be driven like tht and blah blah blah but hey,to each his own... I read a bunch of stuff on the forum and other places but got curious and was messing around in the fuse box. I unplugged one fuse tht was a 10 amp labled E-TCS, started the car and it sounded like it was gonna die so i shut it off and put the plug back,changed my oil and started the car. When i started it ,it ran as well as it always does but i noticed the vsc trac,vsc off and TC light was on,so i tested in the feild by my house and was suprised to see i can spin the wheels in 2wd now..anybody kno why this is or if it will effect any other driving? I have yet to test it out really
Sent from my SM-G965U using Tapatalk
Similar problem here. 2007 V6 2WD/4WD sport edition. Gas attendant forgot to tighten cap and a day later i get a check engine light and the below 3 lights to the right. I tighten the cap and a day later the lights are all gone. 2 days pass and i get vibration going to work. noticeably worse when i brake. i pull over and notice a burning smell from the front passenger wheel. i drive the truck back home after work and no vibration what so ever. 30min in i park and shut off the engine. i turn it back on 5min later and i get the the same three lights, break light, but no engine light. pull over again to check the front passenger wheel. the wheel is slightly warmer than the others with a slight burning smell. not as bad as the morning. i did some reading but cant come to a conclusion. any suggestions? should i just bring it to the mechanic? thanks
Found the issue: I had a break leak. Had the lines replaced. Issue didn't come back.
