vsc??
crashman
I just put my tires on Monday and noticed I get the vsc coming on when I turn sharp at slow speed, at first I thought it was ice but i noticed this morning there was no ice and it came on again. I got a deal on the tires one was new and 2 were about 50-60% I also got one new tire to match the other new one, my question is with new on the back and used on the front could this be the reason and if so will it hurt anything to run until I can get new fronts?
You need to re-calibrate your VSC is all. The stability control system uses real time analysis of your trucks pitch and yaw angles to determine actions.
In placing NEW tires on the back and OLD on the front; you have affected your trucks default pitch rate. resetting the VSC will fix this.
OR putting 2 new tires on.
Do a 0 point calibration.
OR: Check your ABS wires. Might be loose. I think a VSC issue it blinks?
I will look up 0 point here in a minute thanks
when I get new fronts will i have to reset it again?
funny thing is Discount tire sold me the warranty on the used ones I just hope I can use it before they wear all the way out and there is my new tires
patnewton
