wallytoo
Member
had a click-no start today. first time that's happened with my 4runner. after about 15 key-turns, the starter finally engaged and it started right up.
i've already addressed the factory wiring flaw in the starting system as outlined and broken down by RAD4r. and, a few months ago, my wife's '97 corolla had a solenoid contact issue, which i fixed by replacing the worn contacts with new. in doing this, i discovered that my 4runner has the same starter series as the corolla, so when it didn't start today, i figured it was the solenoid contacts.
and i took pics of the process.
there it is, in all it's so close yet unnecessarily difficult to remove glory. requires 14mm sockets or wrenches to remove, along with extensions/swivels. i chose to remove the fender flaps to get a better view.
second pic shows the 27 year old starter on the bench. a little corroded on the outside, but not bad. i wire brushed the bellhousing contact areas, so they are shiny.
third pic shows the cover that needs to be removed to access the solenoid parts - the contacts and the plunger. the three bolts (w/philips) are 8mm. i squirted the bolts, along with the contact studs, with PB'laster. the cover bolts came out with no problem.
fourth pic shows the battery cable connection and the solenoid energizer wire.
