Want to install trailer hitch (how much?)
kdub627
Member
Well I have a 2008 Sport Edition that does have the electrical hook-ups but does not have a hitch. will they have to cut into the bumper?
Also how much does this usually cost?
Curt makes a nice one... No cutting.:dancin: The hitch link in my sig may help.
:cheers:
I got a Valley class 4 on ebay and love it!!! $136 with shipping 30 min install no cutting perfect fit!!!! doesn't even touch the bumper
It was in the $130-$140 range from the Toyota dealer. I used a ratchet, and basically just laid on my back under the truck using my legs to hold up one end of the hitch until I got a couple of the bolts in. I was very easy. No cutting on my 2006 bumper. The Toyota hitch has survived a couple of salty winters without visible rust so I see that as a big plus. Also, I have used it to pull a 6x12 trailer from Jacksonville, FL to Chicago, IL and it worked great.
I don't know what the load range of the Toyota hitch is but the only one rated III/IV 5000-7000# that I know of is the Hidden Hitch #70411. I don't know if it is still available since I got mine a couple of years ago. Hidden Hitch, Reese, and Drawtite are all the same company now. The downside is that I had to remove the rear bumper facia to install the bolts that go into the center of the cross member. The only modification is that I had to cut a notch of about 1/2" for the receiver.
I tried the Hidden Hitch # 70779 but it wouldn't fit around the brackets at the bottom of the facia and it has no center mount to the cross member.
I have the 70779 HiddenHitch. The bumper brackets need to be removed, haven't noticed any issues with the bumper either. I didn't have to remove the bumper facsia to install it, no cutting either.
delislerebecca
