eric_rosenwald
I bought my 2000 4Runner used, in May. The engine still sounds new! I had it inspected, and I was told the brakes were in great condition.
Not long after I got it, I noticed that at highway speeds, when I stepped on the brake pedal, a loud shimmy/vibration started that resonated through the whole car. I assumed it was an alignment, etc. issue. I had it aligned and had a front left tie rod end replaced -- The tech said that it wasn't about to fail and wasn't an urgent fix, but I got it replaced anyway. The brake/vibration problem was so occasional that it was impossible to tell if the vibration problem was solved. In general, it seemed to work. I did feel some vibration a few times though.
About a month later, I went on a long road trip. I was coming down a steep road from a 12,000ft mountain, and I completely forgot to put it in 2nd gear! The brakes had quite a workout, but like I said... There was plenty of life in them. When I got to the bottom of the mountain, I noticed that I had that same brake problem again, except this time it was more intense and loud. Then I noticed a bad smell. I pulled over immediately and noticed that the left rear wheel was stinking of something burning. I figured I had killed my brakes because it was so steep and I wasn't using engine braking.
So not long after, I took it into a shop. The guy showed me everything. It turns out the brakes were fine! What he noticed though was that the axle was leaking oil... He said that it's a common problem on 2000 T4Rs -- they need new rear axle seals. He had a brilliant explanation for the smell. Considering the fact that I was using the brakes so much, the axle/wheel/brake area was getting very hot. Because there was a leak and a widespread film of half-burnt oil had developed in the area, it started to burn a little when the brakes got hot. No problem with the brakes at all. He said the seal issue wasn't urgent, either.
A few thousand miles down the road, I got the rear seals/whatever fixed in the axle. It was good to go. But not long after, I noticed that when I was idling, and I let off the brake just as I started to roll, the entire vehicle started shaking violently. I stopped immediately and it would go away. When someone else drove it, I noticed that the rear left tire (the one where oil was leaking out a lot into the brake area) locked up! The other wheels were rolling, but that tire was dragging. It was going about 2mph when this happened, so nothing major resulted. I assumed it was some kind of transmission issue. This violent shaking would happen ONLY when I had just started up the 4Runner, at that slow idle speed. There was no problem, otherwise. When I finally got home, I took it in to several shops to get it inspected... and see if there was a transmission problem. Because it was so irregular (didn't do it every time I started up... maybe every 10th time), they said "come in when you can replicate the problem". It was frustrating, but I don't blame them. They couldn't see any problems.
So I looked up the issue on the forum. Based on what others said, I had a theory that when that differential oil (or whatever oil) was leaking out of the axle and covered the brake area, it left a film or goop of semi-burnt oil. Getting the new seals worked fine, but in the process, the guys must not have cleaned off all of that gunk that was left behind, and ended up leaving some that interfered with the speed sensor. When the 4Runner started to roll at idle, it thought that the rear left wheel wasn't spinning, and activated ABS. Keep in mind, I had no engine lights or ABS lights throughout any of this. The reason that the ABS light didn't come on was because it didn't think there was a problem -- it simply thought that the left rear wheel wasn't spinning, and freaked out by kicking in ABS. So a few days ago I took it into a shop to have the brakes, and the brake area / axle area cleaned, and told them to clean the ABS sensor. I don't think he paid much attention to the story, though. I took it out of the shop and there wasn't a problem. My theory was confirmed. It was gunk that was covering the ABS wheel speed sensor.
Then... something new came up after a few days. I have to steer slightly to the right, and that left side (I think the problem left rear area) seems to be extremely touchy with the brakes. Super sensitive. I know I don't have an alignment problem because it was absolutely spot-on perfect before this (when he cleaned it, he didn't touch the front wheels). After cleaning it, the original violent low-speed ABS activation stopped. But now it's something new.
I'm sick of dealing with this, and I'm considering just taking it into the dealership -- even though it's more expensive. An easy theory would be that the speed sensor is shot, but if that were the case, why did the super-annoying low-speed ABS activation problem stop, after it was supposedly cleaned? Also -- why is the 4Runner wanting to tug to the left (especially when I brake) if it just got cleaned? Shouldn't there be less friction on the left side? I have to steer slightly to the right at all speeds, but it tugs even more to the left when I brake.
Any thoughts or suggestions? Thank you for being willing to read this long post!
