MadeInMaine
I am getting ready to snag a lift kit, but I am curious about the details of what the rear lower links are for?
and I know its a rookie question....
Cheers
Cheers
THey also limit travel of the rear axle unless you get the offset lower links that many companies offer.
He is talking about down travel. If you have long travel, the link will bind up against the axle at full drop. It's borderline, but it will hit with a LT shock.What are you talking abut? Any examples? All of the rear lower links I have seen are straight.
Isn't the upper limit of wheel travel the bump stop or the tires against the fenders, whichever coms first. And the lower limit of travel is dependent on the system, the coil springs and the shocks, depending on whether it's long travel or not.
:thanks:
In a coil spring suspension they keep the axle in place. In a leaf spring suspension, the spring does this.
I take it you mean the forward/backward movement, not upward and downward...
Excellent, thanks for all the info guys!
The offset links benefit a long travel setup the most.
Metal Tech 4x4 FJ Cruiser/4Runner Offset Rear Lower Replacement Links
Also like those Total Chaos front lower control arms. Better than a LCA skid plate I presume.
Also the stock lower links are somewhat weak as I found out the second time I wheeled my truck. I crested a hill and hung up on a huge rock right on the lower link. Had a slight bend to it after that. It didn't affect the drivability tho. If you plan on really wheeling your rig then go for the aftermarket ones.
So you're a Crazy Norwegian in So Cal, are you?
The bend in your lower link trailing arm had to affect the length, which affects the rear axle alignment. So does adding a lift to the truck, as far as I can tell.
I don't see how anyone can do a lift like the ICON Stage 1 or Stage 2, or any other brand of lift, without replacing the rear links and pan hard bar. Lifting the T4R off the axle pulls the axle forward. If you don't adjust the link arms and cross bar then the axle is pulled forward, shortening the wheel base and alignment sideways due to the pan hard bar is also affected. Some might say the distance is minor given the angle of the links, but it is there nonetheless.
Anyone care comment or shed some light on the undercarriage?
Longer links will move the axle back to the original wheelbase at the new ride height, but what about when the suspension is compressed? Longer rear links will push the rear axle towards the rear of the wheel wells and a longer panhard bar will shift the axle to the left when compressed. This can cause rubbing issues especially when running larger tires. The axle shift when lifted is pretty minimal (under an inch I'd guess) so it's not going to make any noticeable difference driving down the road. Longer links always seemed like a bit of a money grab to me although the strength upgrade is nice. You can reinforce the stock links with angle iron or cut and sleeve them with stronger tubing and get the same effect.
Thanks Nate. That kind of experience and knowledge helps newbies like me understand the parts and mod's. Just one point though. Of course, if you lift the rear with longer springs and shocks the differential is automatically dropped with the straight axle. :jump:
I've looked at Sonoran Steel before. I like Steve's pan hard bar and his lift kit resembles the TRD Pro lift very closely. And he's not offering lower links with his kit either. I see Sonoran has a diff' drop for the front diff on the older T4Rs. I hadn't thought about this for the 5th generation but I see the axle angle is changed by the lift. Steve is actually close enough to go visit from here in So Cal.
Greg, your link did not work. It went to Google Search.
