What are your HIGHWAY mpg's? 4th Gen
Year: 2008
Tire Size: Factory limited trim 265/60R18. Michelin LT.
Gear Ratio if you know it: stock
2WD, 4WD or AWD: AWD - Full time 4WD
Modifications that affect MPG: Hood deflector
Current highway fuel economy: 15 MPG
V6 or V8: V8
Average speed you travel: 74 MPH
Anything else you want to add: I could probably get 18 MPG if I went 65.
Year: 2007
Tire Size: 265/65 17
Gear Ratio if you know it: Standard
2WD, 4WD or AWD: 4WD that I leave in 2WD
Modifications that affect MPG: Roof rack with site stepladders, always full of tools
Current highway fuel economy: 19.2 US Gallon 23.1 Imperial gallon
V6 or V8: V6
Average speed you travel: Unknown, cruise at about 60mph on long journeys but often accelerate hard. D
Anything else you want to add: I always use super unleaded 98+ RON. Equivalent to your 93 Pump I think. They have crappy 10% ethanol standard fuel here now.
Stock 2006 V8 Limited on factory 18 inch rims. Blizzaks in the winter. Kumhos the rest of the year.
16 mpg city/highway mix but mostly gentle highway cruise. Calculated on the trip computer and actual calculation of fuel used and distance traveled.
Occasionally 17 - 18 mpg if I don't drive too much stop/go.
Using the smaller US liters (3.78) to one gallon conversion. The Limited V8 is awd all the the time. About $75 USD to fill up every 2.5 weeks. Not bad for the vehicle that is this capable.
Tire Size: Standard
Gear Ratio if you know it: Don't know
Modifications that affect MPG: Greasing zerks, air filter and oil change
Current highway fuel economy: EDIT: 19MPG after more mileage
V6 or V8: v8
Anything else you want to add: I drive like a grandmother.
I was at 22 but as soon as I stopped at some lights and what not, the mileage dropped fast.
19mpg? Dang man! Good on you!! Thats awesome.
Year: 2006
Tire Size: 285/70R17 (Randos that were on when I bought it)
Gear Ratio if you know it: Don't know. Standard
2WD, 4WD or AWD: AWD?
Modifications that affect MPG: Small rack behind sunroof. Has a spacer lift.
Current highway fuel economy: Anywhere from 13-15mpg
V6 or V8: V8
Average speed you travel: 65-75 on the highway.
Anything else you want to add: I feel like I am getting worse mpg than others. I am slowly going through the truck and changing everything out. Fluids are being done next. So far the brake fluid and power steering fluid were black from the PO.
My ultra gauge says the average is 14.6mpg, but I forgot to reset it before I went on a trip this weekend. LCD screen says around 15.7.
edcultural
