What are your HIGHWAY mpg's? 4th Gen
272k miles! anything major that has been fixed?
Wheel bearings, valve cover gaskets, radiator and tie rod ends are the only things I've done outside of the Toyota maintenance schedule.
Still even has the original alternator...
Edit: also replaced water pump twice, replaced the thermostat 255k as gasket was leaking
May I ask, will you be wanting another 4th Gen or newer? If you are looking for a 4th Gen, will you be looking for a V8 or V6 again?
Sent from my A0001 using Tapatalk
I'm currently on the lookout for a newer 4runner since I'm giving my 2004 to my oldest son to drive to school. I'll most likely be looking for another V6.....late 4th gen or even an early 5th.
Year: 2006
Tire Size:265/75R16
Gear Ratio if you know it: Stock
2WD, 4WD or AWD: 2 we
Modifications that affect MPG: pedal commander, exhaust, and drop In filter.
Current highway fuel economy: 18.5 mixed
V6 or V8: V6
Average speed you travel: 75
Anything else you want to add: I generally drive about 75, lots of mixed driving for me.
Driving highway to my sisters house this weekend 75mph got 20mpg best I ever got. All hand calculated after fill up.
Year: 2008
Tire Size: 265/70r17 BFG KO2's
2WD, 4WD or AWD: AWD
Modifications that affect MPG: 3" spacer lift
Current highway fuel economy: 21.9
V6 or V8: V8
Average speed you travel: between 55 and 60
Anything else you want to add: My commute is pretty much exactly half 55mph limit, and half 60mph. Most days I'm on cruise control almost the entire trip. Economy is based on trip meter/fuel to fill, trip meter is not adjusted after tire size increase.
Year: 2006
Tire Size: P265/60R18 / Stock
Gear Ratio if you know it: 3.73 / Stock
Modifications that affect MPG: 1.5" TRD Off Road Taco Suspension Swap
Current highway fuel economy: 19.0
V6 or V8: V8
Average speed you travel: 60-75
Anything else you want to add: Road Trip from Socal to San Luis Obispo and San Francisco, averaged between 18-20 mpg the entire way mostly Highway 101
Year: 2006
Tire Size:265/75R16
4WD
No mods.
Current highway fuel economy: 20-21
V6
Average speed you travel: 65-75
Anything else you want to add: When I got it this June it was averaging 23 on the interstate, but that seems to have slipped a couple mpg's...maybe winter gas and colder weather?
And the computer seems 1 or 2 mpg optimistic compared to manually computing the mpg...
Year: 2008
Tire Size: 265/70/17
2WD, 4WD or AWD: 4WD
Modifications that affect MPG: URD LT's, lifted 3", Gibson catback
Current highway fuel economy: AVG 22.5, best 24.8
V6 or V8: V6
Average speed you travel: 64 MPH
Truck got 17-19 as I bought it. 20-22 after tune up, plugs, filters, gear oil, ect. Amsoil gear oil an engine oil, OEM plugs, Wix filter, cleaned MAF sensor, new OEM PCV, ect.
Added URD LT's, all new o2 sensor's, an set my hand calculated record @ 24.8 MPG.
Truck has 171k miles.
Year: 2008
Tire Size: 255/75/R17 Goodyear Duratrac
2WD, 4WD or AWD: 4WD (but I drive mostly in 2WD mode)
Modifications that affect MPG: 32" tires
Current highway fuel economy: AVG 21, best 22.5
V6 or V8: V6
Average speed you travel: 65 MPH
Anything else you want to add: I purposely went with 255/75 tires to try to preserve as much economy as possible...I'm pretty happy with it for now
Year: 2007
Tire Size:265/65R17
2WD, 4WD or AWD: 2WD
Current highway fuel economy: 20 MPG
V6 or V8: V6
Only have taken one hiway trip, and this is what it averaged out. The trip computer is so wrong, at least 3 or 4 mpg optimistic! I get 17-18 mpg around town.
Year: 2008 Limited
Tire Size: 265/60R19 Michelins
Gear Ratio if you know it: Factory/Unsure
Modifications that affect MPG: None
Current highway fuel economy: 20.5 at 70 19.5 at 75
V6 or V8: V8
Anything else you want to add: Bone Stock
Sent from my Mi MIX 2S using Tapatalk
Year: 2005
2WD, 4WD or AWD: 4x4, keep in 2WD unless rainy
Current highway fuel economy: 22 @ 65mph, 18 @ 74mph
V6 or V8: v6
Average speed you travel: 3mph over
Anything else you want to add: I drive like a grandpa.
Year: 2007
Tire Size: Stock 265/65/17 (but A/T, not highway tires)
2WD, 4WD or AWD: 4WD (always in 2WD except offroad, in bad weather, or doing the monthly "use it or lose it" maintenance)
Modifications that affect MPG: Reduced rake due to Tacoma TRD OR coils in front (maybe?)
Current highway fuel economy: 19-21 (can get 23+ at 55 mph, measured with OBDII scanner reading real-time MPG)
V6 or V8: V6
Average speed you travel: 65-80 depending on speed limit/conditions
Anything else you want to add: N/A
Looks like I'm the only one who really sucks.
Year: 2006
Tire Size: 285.70.17 Falken AT3W Load C
Modifications that affect MPG: Shrockworks bumper, heavy sliders, TC Mid Travel, Thule 16 cu ft roof box. Only including Thule box because I used it during MPG calculation.
Current highway fuel economy: 12.82
V6 or V8: V6
Average speed you travel: 80+ Keep in mind I learned to drive in NJ, so I do drive like the stereotype.
Sent from my SM-G981V using Tapatalk
Year: 2004
Tire Size: 245/70-17
Modifications that affect MPG: Skinnier than stock tires, but same height
Current highway fuel economy: 19.6 on gauge, 18 actual hand calcd
V6 or V8: V8
Average speed you travel: 74
Anything else you want to add: Recent 800 mile round-trip using Google Maps for distance rather than odometer, and then hand calcd
Year: 2008
Tire Size: 285/70-17
2WD, 4WD or AWD: 4wd, 2wd except when off-road or inclement weather
Modifications that affect MPG: tires, plate bumper, sliders, steel skids, hitch tire carrier with full size spare and hi lift jack.
Performance (lol) intake, Flowmaster 50 suv, 3° retard cam gears, XTP intake plenum spacer.
Current highway fuel economy: 17 thanks mainly to the cam gears, they make a good difference. City driving is about 15, which is pretty good considering all the extra weight.
V6 or V8: V6
Average speed you travel: 70-75
Anything else you want to add: I love this rig and will take the poor mileage.
Sent from my SM-G986U using Tapatalk
year 2007 SE new
Stock tyres
No mods, all stock.
4.0 V6
Interstate: 65-70 listed
2 drivers averaged 23 MPG one day. (Southern Oregon to past Bay Area, CA)
Year: 2004
V6 or V8: V8
How do you like the 245's? I run 255's but recently I've seen that size in some all terrains. Curious to compare weights and wondering how they do in snow.
Its not even 1/2" so probably not much difference.
The tires came with the car when bought so i cant compare to the original 265s. Tire size calculator says the height difference is only 0.06" or 1/16" compared to stock 265/65-17. When the time comes im looking to go with 255/70-17s. I also have no experience in the snow, we dont get that here :sobbing:
Year: 2005
Tire Size: 35" MT
Modifications that affect MPG: Full armor, no roof rack, 3" lift, 1.5" BL
On the same day driving from Colorado to Kansas, flat interstate:
@73mph a full tank gave me 18.5mpg
@80mph a full tank gave me 16.5mpg
V6 or V8: V8
Anything else you want to add: Calculated by hand and added 12% for tire diameter.
I think this needs an update lol
I'm not sure but I think this is after I installed the speedometer healer which corrects the speedometer which in turn corrects the odometer to compensate for the larger tires. So by manually correcting for the 12% difference I doubled up on the math.
So I think my actual numbers with 35's were:
@73mph 16.3mpg
@80mph 14.5mpg
With 37's I think its closer to 11 or 12 in town commuting.
pugowks
