what coil to go with
BLACKHAWK250
Hey guys, my GF recently got a 99' 2.7L 2wd 4runner. I got her Bilstein 5100's for all 4 corners for Christmas. But I want to get her new coils to raise the front up to leave the shocks at 0 preload for better ride and achieve about 3" of lift to run 32's. (BTW Camburg UCA's and Total Chaos spindles gussets will be used with this shock/ coil set up) Now im debating what coil to get and why. I know the Tacomas with the 3.4L and 4x4 use 5100's with the toytec/ eibach 620lb coil and like it, but her truck is a 4 banger so i believe this is way to much and will be a stiff and un-friendly ride? So now im looking at OME coils and the ones that have cought my attention are the 882 which is 502lbs- 395mm's tall or the 885 which is 588lbs at -395mm tall. Both much less then Eibachs 620lbs spring
Im thinking the OME 882 because its a moderately lighter coil and used with V6 4x4 tacoma's and since 4runners are heavier then tacoma's i think it will compensate for the 2.7L 2wd?? I know later gen 4runners with V6's and 4wd use the 885 at 588LBS, so if heavier trucks with larger motors and 4wd use it then it must be to heavy for my set up so 500LBS with the 882 would be better? Thoughts on this please
Also they make multiple lenths, but since im trying to achieve 3" of lift, i thought 395mm tall is the best option. Not a shorter spring like the 883- 588in/lbs- 375mm's tall. 10mm shorter= shorter ride height correct or am i thinking wrong?
OME's spring rates and lengths:
880- 502in/lbs- 365mm's tall
881- 502in/lbs- 375mm's tall
882- 502in/lbs- 395mm's tall
884- 588in/lbs- 385mm's tall
885- 588in/lbs- 395mm's tall
886- 656in/lbs- 402mm's tall
thanks in advance guys,
Cole
