Park the Camry sideways in front of the garage door as tight as possible. Will possibly help protect the Camry but will also Protect more of your garage door from the wind. Reality is, you shouldn't even be there anymore. I have some friends and family down in Florida and they haven't left. If you get anything like they're saying you'll get, there won't be anything left to worry about. Your life and safety is a priority, objects can be replaced, leave!
Will do on the Camry, I still need to use it to check on some neighbors. We are pretty far inland and 30 feet above sea level, (that's a lot for down here). The highways are jammed with people in mandatory evacuation zones. Tanks are full but gas is scarce. Nowhere to go anyway and it will be hell trying to get back. Modern block home, built in 05. Holding steady.
Picked up a Mombasa RTT on our way to southeastern Oklahoma for a quick weekend trip!
Mounted on the factory rails currently, which is why it's hanging off the back instead of the side.
Stay safe and you could wrap a mattress on the camry to help protect it from debris. I use a egg crate mat to protect from hail here at home. So a big mattress should help with some wind debris . But seriously stay safe.
Installed my ARB twin on-board compressor with help from [MENTION=81106]Cytronus[/MENTION]
I still need to buy a switch that fits my dash panel, wire it up, and buy a quick-connect fitting for it.
When I woke up I had big plans for a lot of changes to my 4R, but didn't get as much done as I hoped. The original grill and garnish was removed and replace with the TRD Pro version. I pulled the silver valance off the bumper, so I could wrap it with matte black vinyl. Unfortunately my first attempt at wrapping the panel went horribly wrong. My teen-aged son assured my he knew how to apply vinyl...he doesn't. :Cry: We ruined the one sheet of vinyl I had that was big enough, so now I need to order more.
Getting lock in by a #######.
...I just finished installing my winch 2 day ago... The temptations of trying it for the first time is overwhelming.
Gave "Frosty" some belly protection, because I was told the first time I ran the Rubicon in my almost stock FJ40, "...you can't surf rocks, without a good surf board...."
RCI skid plates - great quality and relatively easy to install.
Took the fam out on the "boat" today... A full length roof rack is definitely number 1 on my to install list!
2016 TEP w/ KDSS. FN FNX Pro wheels. C Load BFG AT T/A KO2 265/70R17.
Ladder installed!
<img src="http://i116.photobucket.com/albums/o21/acurawei/20170909_190200_zpsctqvu9kb.jpg" border="0" alt=" photo 20170909_190200_zpsctqvu9kb.jpg"/>
<img src="http://i116.photobucket.com/albums/o21/acurawei/20170909_190046_zpsrfizzwkl.jpg" border="0" alt=" photo 20170909_190046_zpsrfizzwkl.jpg"/>
If/when I get a compressor, I think I am going to put the switch right next to the compressor instead of running a wire inside the cab. You have access the compressor to hook up the hose anyway so the switch will be right there after connecting the hose. Just makes more sense to me and way less work. :noidea:
Gave "Frosty" some belly protection, because I was told the frist time I ran the Rubicon in my almost stock FJ40, "...you can't surf rocks, without a good surf board...."
Will you be selling that TRD skid plate ?
