did you have a shop do it? or did you self apply? looks even
The wire hiders? Thanks. Warmed them up a little w heat gun on low, helped straighten them out. Then butted up against the windshield molding. Cleaned the glass as directed and tried to be patience while getting it to look straight.
Vacuumed/shampooed upholstery. Installed redarc tow pro liberty for the new camper.
Did you use the TPSI-002 switch insert from Redarc? I have the TBC on order.
Swapped my Viofo A119 for the A129 dual channel dash cam. Thanks to [MENTION=452053]papadakko[/MENTION] for the STL file for the rear mount.
oil change, grease the u joints......dropped the plastic filter cap bent the metal cylinder, ran outta grease, bought 1 qt of the wrong oil weight. Life is hard being this dumb.
lmao. sounds like one of my DIYs. whenever my hood is open I always drop 2-3 tools or bolts in my engine bay and have to spend time getting them out
Took the fam up in the mountains to get a tree before the snow storm shut the roads down for the season. Had a friend and her fam join us in her JL. A good time was had by all.
This does not top my ‘filling 6 qts of oil then realize Fumoto valve wasn’t closed…’
Well i was doing a oil change, and i was starting to break free the bolt on what I thought was the oil pan, only to remember i installed a fumoto valve a long time ago........ Luckily, i stopped right there and didn't break free that bolt when I realized that bolt wasn't for the oil pan ROFL.
modified front runner drop down table
re-purposed a gun magnet to use as a passive / back up fail safe in case the front runner main latch decides to fail, since the table sits about 1/2 a inch from the hatch. No safety wires, no fiddling of extra latches, no bungie cords.
gun magnets are cool because they usually have non-scratching coatings (rubber/plastic).
Trying to make my ghetto mods look less ghetto.
The only thing allowed on gun magnets are guns! You're doing it wrong! LOL!
refinish front runner table
So there is a reason why front runner drop down tables use to sell so cheap (or at least when i bought it a few years back before RIGD started reselling them with huge markups).
Front Runner's drop down table was never designed to sit on a tire carrier so the wooden extension is literally untreated birch plywood.. It's not very weather/water/uv resistant and will deteriorate quickly if left outdoors.
Anyways decided to refinish them w/ left over poly and left over plastidip and is suppose to be a stop gap measure until i can make a custom plastic extension out of 1/2 HDP plastic. This is not meant to be perfect. It's only meant to stop the deterioration until i get around to the 1/2 HDP plastic replacement.
I might poly some brewery decals into it if i wasn't so lazy. Maybe it will be a future project.
And this is why I've gotten in the habit of triple checking just about flipping everything if it's not written down. If I don't I'm bound to float around aimlessly aloof (and still do much of the time) and mess all sorts of things up (and still do much of the time). Especially locks whether it's running back to the front door after I'm already in my car or checking a ton of times anytime I get out of my 4runner with it running to say hookup my 4 way inflator setup (I really need to find an extremely inconspicuous spot to ziptie a spare).
I received a couple of things I ordered from Amazon:
An altimeter and barometer. The barometer is incidental (I live in eastern Washington up along the Cascade foothills-the prediction is "SNOW" for the next 2 months!). The altimeter is important so that I can tell if my breathing problems are from the altitude or my heart/lungs.
Amazon.com : Sun Company AltiLINQ - Dashboard Altimeter and Barometer | Altimeter for Car and Truck | Reads Altitude from 0 to 15,000 Feet : Sport Altimeters : Sports & Outdoors
And a behind-the-seat Molle rack for the 4Runner. Keeps things handy such as our digital camera, flashlight, knife, etc. First Aid still goes into the large First Aid kit in the back.
Amazon.com: Molle Seat Back Organizer, Tactical Car Seat Organizer with Pouches, Tactical Molle Vehicle Organizers Panel Universal Fit Car Khaki : Automotive
Liked it so much I got one for the wife's RAV4, which is an abomination behind the front seat!!
Once I get the guts to trudge through the snow and brave 18-degree weather, I'll install them.
Oh, I also bought some connectors and a length of threaded rod to extend my Hi-Lift mounts so that they will hold my traction mats on my rooftop carrier.
labops gear dash mount and 67designs tablet holder/nano arm....sheeeesh this stuff is clean. install of the lab ops mount was ridiculously easy and clean. it looks OEM
