Got most of the service records. Timing belt 15,000 ago. needs a deep cleaning. RRlocker light flashing. don't think it was ever used. It may need service to get working. Any advice on the locker is appreciated! Oh yeah, I bought it. $1600.00. I will post pics as soon as I get it back home.
Me thinks u done good and congrats.
Can't wait to see pix.
Eddie
Fixed the broken cup holder with a couple of drywall screws. No pics but simple process. Basically replaced the broken plastic stud with the screw cut the head off and grind smooth.
Project "Changeling Build" commenced.
I was able to get it to my friend's garage to begin to tear it down and build my Changeling 2002 up. I pulled the coilovers to send off for rebuild with 650# springs. Pulled skids and am in the process of working out the order of things to do and gathering up all the needed torque specs.
New UCAs with uniballs! Hopefully the last time for a long time that I need to mess with those retainer clips that are a PITA!
Couple o'piddly things. One of them was to dim the high beam indicator because it really hurts my eyes.
I can still see it, but now it's not a bright blue death laser eating my brain through my eyeballs.
a bit of plastic cut from a folder and glued into place to knock the oomph down quite a bit. It looks the same other than being a deeper, more quiet blue.
changed the rear diff gear oil. still had some color after 9,200 miles but given the vehicle just had its 21st b-day, i thought i should do it a favor. next is an O2 sensor in hopes of abolishing the P0420 CEL code.
Re-torqued my front end suspension I installed over the past several weeks and currently waiting on glass guy to fill in a chip in the windshield
O2 sensor, as promised. the new Denso 234-4162 appears to have been the correct choice for a '99 non-california / federal 4WD, despite amazon's part selector insisting it wouldn't fit my application. i used the denso part-finder and went with that. if anyone gets one of these, be aware that its lead is fairly short, compared to the OEM part, and there's some annoying effort spent fishing the connector up over the transmission to get it all hooked up. in the end it does work, and there's less wiring to flop around up there.
Completed the 30K service just before she hit 200K miles:
- oil
- air filter
- trans fluid flush
- transfer case and diff oil
- grease u-joints
- coolant
- spark plugs
Exhausting!
Still need to do the brake fluid, but I am torn between just flushing it or replacing the whole master cylinder with a Dorman for the simple reason that my reservoir is almost black and that annoys me.
Also ordered a new OEM fuel filter, to get her ready for the next 200K :).
We have these on my bike forums and didnt find one here with the search. So lets get this started. As the title states, what did you do to it today?
New plugs, wires, cleaned MAF and throttle body. '96 limited 159,000 miles. Just bought last week. NO RUST!
Sonoran steel washer bottle relocate and rav 4 washer nozzle upgrade:bathbaby:
That must have set you back a pretty penny. I’ve been looking at aluminum washer tanks off eBay for $20-40 but the install of the OEM plumbing is going to be interesting. I may just cough up the extra $ for the SS one.
Kamakazi deer tried to kill me
New oil filter housing seals
energy suspension end link bushings and front sway
Ac delco end links
4 new dynapro HTs
Clear signals
Led license plate and side marker bulbs
R&R rear wiper arm
It was a few days ago, but I put in a Kenwood DMX7706S double din.
CarPlay is really cool, my favorite feature.
Hi,
So I have this same stereo, but I haven't figured out how to get my carplay to work. I procrastinated a few months, but still wondering. My iphone keeps telling me to hit the speaker function on my steering wheel, which obviously does not exist. Any tips?
Replaced the driver door window regulator and motor, as well as topping up the front diff fluid from swapping the passenger CV axle the other day.
AndiGarage
