Read that the 881s are a hair stiffer, wanted to go for more comfort. The springs I got were about $220 each. Sure you might save a couple hundred bucks, but I justify it by saying that's just 4 tanks of gas.
Ah, got it. A hair less stiff and progressive rate, so that makes sense to me!
New family member
I dropped the tow hitch to sand and repaint. My 02 is in amazing condition. We have owned it for the 18 years, serviced it religiously at the same shop and it is bone stock.
It has a few dings acquired over the years so I am systematically working them out and just got permission to do some mods.
Griff
Removed front and rear bumper painted them with Raptor liner also removed running boards and installed new mud flaps all the way around. Finally starting to look the way I want. [emoji869]
Coated the inside of the frame with Eastwood internal frame coating. In the fall I plan to spray some Fluid Film inside the frame also for extra protection.
Looking good. Did you spray on or roll on the Raptor liner?
Just sprayed with the can then let dry overnight, it was pretty easy however I’m curious to see how it will hold up over the chrome. I sanded and primed really well. That part took longest.
Masked the chrome off on my front grill and painted the black accents with a fresh coat of semi gloss black to get rid of the 19 years of road rash.
The grill looks brand new now
I drove 1 mile with my e brake on... smh
I'm gonna install a buzzer to remind me so it doesn't happen again.
Dropped her off at the body shop for some TLC. Always a stressful experience since you never really know what you're going to get back. Fingers crossed.
Installed toytec adjustable rear links . Played with my rear end geometry to correct some vibrations...we shall see everything seemed good today below 50 mph.:lookout:
Timing belt
Water pump
Thermostat
All pulleys and new hydraulic tensioner
Valve cover gaskets
Rear cam plugs
Spark plug tube seals
Spark plugs
Injectors
Oil cooler seal
Oil cooler hoses
Oil filter
Exhaust manifold gaskets
Not my 4Runner but I am doing the work. Jdm engine swap
I kind of like the running boards on mine my girl is pretty short but can’t stand the fender flares how bad was it taking the flares off??
Not hard at all, took about an hour to remove all the cladding. I didn't do it the way other tutorials recommended (removing all the interior panels), I just yanked it all off. That does damage more clips, but clips are cheap and time is money - and removing all the interior trim risks damaging other things.
This leaves the body with over 60 holes though, so you'd have to be ready for a full repaint if you want to leave the cladding off and patch the holes.
I'll be writing up a tutorial on this project once I get everything finished.
Timing belt
Water pump
Thermostat
Valve cover gaskets
Rear cam plugs
Spark plugs
Injectors
Oil cooler seal
Oil cooler hoses
Oil filter
If you have gone that far might as well reseal the oil pan and replace the rear main......:cheers:
I replaced my PCV valve, grommet, and hose today. In doing so, I realized that the PCV hose and the hose connecting the upper plenum to the intake had been cross connected which explained the oil in my intake I was noticing. While working on the PCV valve, I noticed that I have some insulation that has come off of what I believe is my injector wiring. See picture below. Can anyone confirm that is the injector wiring, and assuming it is, does anyone have an idea of how much of a pain that is to fix?
Took it for a drive down some dirt roads in AZ after getting an alignment. Just installed 5100s all around with 906s in the rear and stock 99 talks on the 2nd perch. Future will be bigger tires and maybe coil spacers in the rear. Rides like a dream after getting the “made in Mexico” unbranded struts off the front!
