From the pic it shows that Caster and SAI (Steering Axis Inclination) are both out of spec on the left side. It doesn't effect tire wear unless drastically out of spec but will cause you to have both hands on the wheel to make the truck go straight.
My truck was having the roar at 35ish miles per hour.
So, I did an ECGS Bushing, and new drivers side CV Axle.
The roar seems to be gone... :high5:
Let see if it stays gone!
Hi. I'm not sure if I'm posting this to the right spot, but I have a 99 3rd gen 4Runner. I pride myself on its condition, however I made the poor choice of allowing my daughter and her friends to use it. Apparently, while driving down the road at approximately 30 mph, it was jammed into four low.. Now, the transfer case acts like it is stuck in neutral.. I can move it from two high to four high to four low like normal, but it won't grab any gears, and in park, it rolls like it's in neutral. When I put it into drive and reverse, I can hear what sounds like parts moving within the transmission or transfer case, but the vehicle won't go into gear. There's no grinding, and no resistance when shifting the transfer case. It starts normally, so I don't think it's the flexplate.. I'm guessing it could be the actuators within the transfer case? Is it completely shot? Any advice would be helpful, I always try to do my own work, but I'm stumped on this one.
Thanks!
Tranny and transfer case probably toast.
Drain your tcase fluid see what it looks like
Same with the tranny.
Thanks!
Drain both the fluids, drop the tranny pan. Unfortunately I have a feeling that's where you'll find the gear's teeth.
Then make her contribute all she can to a new, fresh tranny and transfer. :director:
"ditch the girl, not the car"
In regards where to post, this is about as good a place as any - when you're a new member you can't make a thread yourself until you've posted 10 times, but this thread is obviously very frequently updated and checked upon
Well that's wonderful! I'm heading out to my garage now to make a better assessment of the damage, but you basically confirmed my fears. Believe me, she will be contributing greatly to the new tranny, and it'll be the last time I let her use my runner!! Kids... Gotta love them.
By the way, I'm so glad I've found this forum. Very valuable resource!
If you don't find any fragments/material and the fluid looks good, it might be worth posting around and making a thread for yourself since not everybody comes through this one. Last I checked our Aisin trannys can be had for relatively cheap (or at least less than expected) so you might be in luck. Replacing them isn't particularly complex, just very tedious and time consuming, which is why shops charge out the ass to do it for you. Not sure whats the deal on transfer cases though, but I bet Timmy the Toolman would have an idea.
Ok. Thanks!!
y'all are straight up insane letting women drive your car! :lmao:
Yeah, that's a terrible idea! She should have her own!
Gender doesn't equal a specific performance or lack thereof....
unless you're worried they will have to have 2 4Runners as a result.
No, that can't be it, there's no bad thing about 2 4Runners.
[MENTION=216747]BeardedUnicorn[/MENTION]
Good for your wife and for you for letting someone else have the wheel.
Have you heard about Stocker No Locker?
Took out my steering knuckles to press in the part for the JBA upper control arms. Also going to clean them up and paint them.
How do you like the JBA arms? Was about to pull the trigger on them, heard good things but kinda curious how much extra articulation they actually offer. I'm somewhat disappointed in the amount of droop the TRD lift gives, but that's IFS for you
Most importantly, noticed any squeaking? My current (OEM) UCAs are squeaking and driving me nuts.
[MENTION=5345]habanero[/MENTION] Thanks for the reminder about stocker no locker. I had completely forgot about those events. I was letting her drive around in all wheel drive all day. I think she would love an event like that! Two 4runners have crossed our mind but right now she want 4 wheelers. I think with more drive time I could get my 2nd 4runner! Oops I mean her a 4runner! Thanks for the props on letting her drive! Happy wife happy life!
Did an oil change (305k). Noticed my passenger side front diff seal is leaking :whipping2 but I just changed it. It seems like my remanufactured CV axle can move in-out 1/4" on the diff side. Any ideas??
Bikeric - a little movement on the outer part is normal. If the whole thing is moving maybe it isn't seated in the diff correctly?
Ambrose67
