Status
Not open for further replies.
thanks,
also did not know of that forum, so thanks for that too.
Saw your back up light thread, Is that a stock bumper that you painted black ? Looks good. Will be installing a ARB this spring on front, thought of painting the rear black. Not sure how that will look on a silver runner, but looks good on yours
Thanks, it is the stock black bumper that I mounted the lights into. They work great still and still get me dirty looks when I back up.
LOL, and here I am, looking at how to get the seat LOWER (can only do the back) so I'm not constantly banging my head against the headliner. If it were only me driving, I'd delete the seat rails. 6'4" problems... (along with the bad back, joint pain and shorter lifespan).
Thinking your best bet is a Sequoia. lol
Cleaned up some parts for upcoming project, cut a bearing race off, order parts to clean up more parts for same said project...meanwhile no 4runner. Big things happening in March!
Finally got parts for LBJ replacement, valve cover gaskets, and TB/WP.
Hoping to get it all done in a weekend.
I'm considering what to do about the god awful paint. Lots of dead clearcoat all over the roof, and the hood is a lost cause. I might just repaint if its not crazy expensive, even threw around the idea of wrapping it.
Yesterday she got her original rims redone and put back on! First photo is when I brought her home.
Find a painter (or several, an independent will probably be best) and ask them for options. Typically, the majority of the cost is in the prep work, so if you're willing to remove trim, help sand and just generally take on the piddly labor chores yourself, you might find a big discount. Obviously, if you want to do a color change it'll be a whole lot more expensive.
The other option is if it's just clear failure, is to wet sand it back to paint and re-clear only. This is a fairly easy DIY project and you could do it panel by panel if you wanted. Just spend the money on better clear (2-part, commonly called 2k). Again, the quality out is determined by the time spent in prep.
That's a bummer. Whomp whomp
If that's the worst thing that happens today I'm doin alright I think.
Got my MXT275 wired up. Used an Add-A-Fuse on the Wiper fuse. The only blank slot I had didn't get any power at all. Found a ground via a bolt holding a bracket on the left kick panel, no idea how good of a ground it is but it works for now. Using a 4A fuse on the radio just incase.
Ignore the mess.
A friend is actually gonna help me get the clearcoat off this weekend. I'm terrible at detailing related things and historically have not had the patience to do it right. I'm more of the "hit it with a hammer and send it" type.
Got rid of the rotted out stock exhaust...
For the new hotness...
The install didn't come without its hiccups, but it was much more intuitive than a lot of other things I've done lately! Badass tone through all of the RPM ranges and stainless for longevity. Magnaflow hit it out of the park on this one for our rigs!
... also learned about how much is too much grease for our driveshaft yokes. I kept pumping until I saw the sleeve move, but the vibrations I had already been feeling from the toasted needle bearing and old front wheel bearing was way more pronounced after this last maintenance! Took the zerks off from the front and back shafts, drove down the street making sure to be heavy and sudden on the brakes and accelerator, and put the fittings back in. Everything is much more subdued again, so remember... TWO TO THREE PUMPS AT THE MOST! You're trying to grease the splines, not fill to capacity. You need the extra space in there to allow the two sides of the shafts freely move as the suspension flexes.
Status
