..wohoo....just a pinch above 14mpg...first time in months.......so glad that spring has sprung and i spend time out of 4wd. still got a 2+ mile to black pavement to town, and 2+m miles uphill on ice to get home. ( both in 4wd) ....but wohoo.....16mpg not far away
plus i love my j shift....mechanical...just shift in or out....an old guy with simple mechanical pleasures. love this 4runner....one of the best rigs i have owned...i love thier simplicity and reliability but a few years ago I wondered how one would do when i moved to alaska....they kick butt...just dont wreck one as parts ( not simple on line parts) are few and far between.
Rear window down = official first day of spring.
The downside:
That's how I came back this morning after dropping the kids at school. I had to remind them to JUMP out unless they want to look like they had a diarrhea crisis all over their pants :D I'm going to have to rethink these mud guards I reckon. At least they mostly keep gravel off the rocker panels.
Of course I do. Just look at the seat pix I posted.
Only Stevie Wonder would have a problem not seeing the difference between the Sport and non-Sport seats. :D
Eddie
Those part numbers are for sport seats. Do you have sport seats? If you don’t have sport seats did they still fit okay?
Eddie
They just look like regular cloth seats to me. What’s the difference?
EDIT: I should have phrased that differently. They look the same as the cloth seats (dimensionally) in my 2000 SR5 and I have not been able to find anyone stating sport seats are x inches of seat back side bolster protrusion over SR5 cloth seats. I also haven’t seen enough cloth seats from 01-02 to know if the sport cloth seat fabric was different from a base seat fabric.
The reason I’m looking for that information is to know if the seat bottom and back cushions for a sport seat will work with my base seat covers. The base seat cushions are unavailable. If the sport seat cushions are dimensionally different enough then my base seat covers aren’t going to fit correctly.
Decided to re-badge my rear hatch after having removed the badges shortly after I got my rig. It looks super weird to have them back on! But I like it. I also removed all decals from the windows, to include my T4R sticker. Had it on for over 8 years. Momo.75 makes incredible vinyl, it was just time to remove it since it was cracking and slightly peeling. But overall I’m pleased with the simpler, basic look. Hoping to do a drain and fill on the trans this upcoming week, too
Sport seats were introduced with the SR5 Sport model in 1999 and have different cloth/fabric centers and contoured side-wings on both the seat and back. There is a distinct difference between sport seats and base, SR5 and Limited seats.
See here for reference:
Toyota 4Runner History 1999
"Sport Package
Includes P265/70R 16 tires, 16-inch
aluminum alloy wheels with cap,
large wheel arch molding, 13-inch
brakes, 4.100 rear differential
ratio, sport seat with hi-fabric,
sport seat material, fender flares,
four-way adjustable headrests,
cloth door trim, leather shift
knob and steering wheel, hood
scoop, fog lamps, color-keyed
bumpers and grille"
And on the forum:
https://www.toyota-4runner.org/1455414-post8.html
"Sport Package
bumpers and grille"
And on the forum:
I should have phrased that differently. They look the same as the cloth seats (dimensionally) in my 2000 SR5 and I have not been able to find anyone stating sport seats are x inches of seat back side bolster protrusion over SR5 cloth seats. I also haven’t seen enough cloth seats from 01-02 to know if the sport cloth seat fabric was different from a base seat fabric. The reason I’m looking for that information is to know if the seat bottom and back cushions for a sport seat will work with my base seat covers. The base seat cushions are unavailable.
Worked on the brakes of my '99 Limited today. Still have a squishy brake pedal with only my front being activated. Running out of patience and might have to take it to a stealership :rockthrow:
Did you adjust the rear brakes? If they are too slack the pedal will be squishy.
There’s a video for that on Timmy’s channel BTW.
This is my first vehicle with rear drums so I attempted best I could to adjust them. Hand brake pulls within the 5-9 clicks and no leaks within the drums. The rears will activate if I pump the brakes but that was before and after I put in a new (bench bled) master cylinder. I am also having ABS issues where I don't hear the pump come on.
I was following this thread Soft brake pedal
Replaced the ABS pump (before I knew you could pull abs specific codes) and am just completely stumped
The master cylinder requires you to block off the fluid out connections with your fingers when you bench bleed them. You can't just route the output back into the reservoir. Did you do that?
I still have no idea about this either. Can I put the sport foam in my SR5 with no issue then? I have Cover King Neoprene SR5 covers on them. I assumed "sport" meant more bucket like with bigger side bolsters but the leather and SR5 ones look the same dimensions to me? It seems to mean the fabric type but that doesn't make sense when you're just buying foam. Unless it's refers to the adjustment control differences? Or simply the firmness level of the foam?
The second question is if it's worth replacing the spring frame or whatever is behind the foam as well?
I still have no idea about this either. Can I put the sport foam in my SR5 with no issue then? I assumed "sport" meant more bucket like with bigger side bolsters but the leather and SR5 ones look the same dimensions to me? It seems to mean the fabric type but that doesn't make sense when you're just buying foam. Unless it's refers to the adjustment control differences? Or simply the firmness level of the foam?
Going off the part numbers and descriptions (cross referenced with a couple toyota parts websites) the sport and limited (leather) seat cushions are the same part number. It would be nice if they were dimensionally the same but different foam firmness as that wouldn't change seat fabric fitment. I wasn't a fan of the seats in my Limited, but I think that was mostly the lumbar support was too much even with it set as low as possible. I don't think sport seats have the lumbar adjustment. I guess I'm Ray Charles lol
I replaced my seat foam and have a thread about it somewhere here. 98 and older, or non-sport foam will not fill a sport fabric. I got junkyard foam that didn't fill the bolsters/wings. Vice versa, sport foam will not fit in non-sport fabric.
I ended up buying a used sport seat foam to re-stuff my seat. Passenger seats are usually less abused but they have an airbag sensor you won't use if you want to put in a driver seat. Not a big deal, just FYI.
I have not tried to buy from the dealer but there are several aftermarket foam options on eBay. IIRC, I had to move the spring rods as new foam doesn't come with those.
Hope that helps.
Sent from my Pixel 4 XL using Tapatalk
Hope that helps.
Thanks it helps in at least knowing sport foam won't work. And if base foam is no longer available I need to figure out if limited foam fits in the sr5 seat ok. I'll read through those threads.
Finished my orange marker lights and whipped up a faux-satoshi grille
I know the mesh grill is supposed to look cleaner or more retro (actually looks too modern to my eye) but I think how you have it fits in better with the 90s era vibe of the rest of truck, yet still retro. They should have came like this to begin with IMO.
Thanks, it's actually a 96-98 4-Cyl grille. The v6 grille was chrome outline - I'm trying to get away from chrome lol
Ambrose67
