Finally got my fuse block wired up. Not the best ive seen but as of about a year ago i had no knowledge of anything electrical! So i think its not bad! And a big thanks to gaterose for answering all my question about his fuse block!
Nice setup!!!
Got a set of black Method center caps and black lug nuts to give the wheels some contrast. I also shortened the center caps by about an inch. Can't decide if i like the black or chrome caps better.
Chrome
SilverCaps.jpg~original
Black
BlackCaps.jpg~original
Chrome
Black
it is definitely makes the wheels standout with black caps, but i don't know too what looks best.
put foil tape on the inside of the housing for the lights in the door. it looks better, now just waiting for v-leds in the mail. only thing about putting the foil tape in the housing is to not cover the hole so that your not building up heat.
also anyone know what this plug is where the cargo mirrors are. its only on the driver side
IMG_20121208_163621.jpg~original
What color are the wires in that connector? It's most likely the harness for the JBL premium system
This morning I left to go pick my girlfriend up for church, then I remembered about half a mile into my drive that I needed to put the bottom halves of the rear seats in the truck for a concert later. I go home, turn the key to off, and my starter begins cranking and cranking and cranking. So I turn the key to keep the engine running, then try again; no dice, it's still cranking. Remembering I have a remote starter, I pop the hood then turn the key off, and thankfully the safety measures in the engine bay cut the engine off.
I get the seats in and try to crank the engine... Nothing. No clicks, no whines, nothing! I try the remote starter, and what do you know? The damn thing starts.
I get in the cabin and look at my dash, seeing there is a check engine light on, along with my TRAC OFF, VSC OFF, and that "holy sh*t you're sliding" light. I check error codes on my ultragauge and it turns out I have PO345.
A google search turned up with "cam positioning error" and reading into a few forum posts for other vehicles, it turned up to be a bad alternator....
If it ain't one thing it's another. Would Toyota cover something like that?
Maybe with an extended bumper to bumper warranty. Otherwise nope.
Alternators are covered under extended warranties, if you have one.
NVBASSJUNKIE
