Cleaning, cleaning, cleaning.
I picked up an 08 Sport V8 model that joins my wife's 5th gen in the garage. It's in great shape overall and appeared to be in great shape inside until I started looking under things and found enough hair to make at least three more dogs.
After pulling out the seats, console, and all the plastic trim I *think* I have the majority of it clean. It didn't really smell like a dog at all (the PO did a good surface detail) but I have my ozone generator running in it now to take care of any smells and it should be good to go. That was a lot of vacuuming...phew.
I took apart my interior as well. My 03 is in great mechanical shape but the interior was not taken care of. I took out seats, console, carpet, door panels, rear panels, and rear parcel shelf. Super easy to clean carpets out of car. I vacuumed and wiped down everything including floor board and inside the doors. I cleaned every part that came off the car. I had the dash apart for a noisy HVAC actuator and instrument cluster repair and cleaned as much as I could get to inside the dash. 20 years of grime and muck gone.
Spent the day looking for noises. 4R decided to start making a bunch of different noises at the same time. Serpentine belt started squeaking, brake pads started squeaking, one of those climate control motors started buzzing, and the most infuriating of them all, a random tapping noise behind the gauge cluster that i cannot find. :gun5: I hear it over the music and it's driving me insane. Maybe because it randomly dropped over 30 degrees in a couple days. :wtf:
It feels good to have it so clean, doesn't it? The rear interior panels are quite scratched up (I'm guessing from the dog) so I'm going to replace those. I plan on pulling the carpets in the spring to shampoo and pressure wash them when I can let them dry out. They aren't bad but I'm sure they can be better.
If you're [MENTION=413201]SherpaEquipmentCo[/MENTION]
You got a podium finish! Congrats Boys!!
It was a great race! Thank you for watching and sharing it!
how is the output? at least the cutoff part, are they aligned correctly, do the 3 inch drop at 25 feet, we are too high for that 2.5 inch drop.
new headlight looks great. how is the light output compared to the spec d?. i have had the specds for over 5yrs.my only major gripe is the poor light output. was considering replacing just the projectors. are the 2.5mm or 3mm?.
could you post a zoomed out shot showing both headlights with the halo on? -- i mean of the new headlights, and also the link of where you bought them.
thanks:flame:
Here's a video showing light output. I went through my Google Photos and I guess I never took any photos or video of the Spec-D lights I replaced so I don't have anything for direct comparison. Sorry for the potato quality, I forgot I had my phone set to 1080p, not 4K.
https://www.youtube.com/watch?v=BlECR8djUoM
0:01 - Low beams & Baja Designs Squadron SAE (original; haven't sent mine in for the update yet) fog lights
0:09 - High beams
0:16 - Baja Designs Squadron Sport (wide cornering lens) ditch lights only
0:19 - Ditch lights, fog lights, and low beams
0:26 - Low beams, fog lights off
Link to headlights: Custom Retrofit Headlights / 4th Gen 4Runner / 03-05
– TEQ Customs LLC
TEQ quotes 10-12 week lead time but when I placed my order in September, it only took about four weeks.
My configuration:
Like I mentioned in my original post, the light output is by far and away better than the Spec-D headlights. The Spec-D headlights were a good upgrade from the original headlights which were hazed over and overall had weak output. I also replaced the lamps that came with the Spec-D headlights with Osram Night Breaker Laser H1 lamps, so the output was decent, but the way the projectors worked, the lights were more like spotlights and didn't have much splash.
Headlights on
Parking lights only
Let me know if you need anything else.
looks like the lights need to be re-aimed, at least adjust your horizontal, seems too far out. hope your doing the 3 inch drop for your vertical aim.
I finally put the sport hood I acquired a year ago on, after putting on a very ugly wrap.
I have an 04 gold hood for sale btw.
Upgraded/organized my accessory wiring to clean up the engine bay and get rid of the multiple harnesses going through the firewall. Went with the PowerTrays mount and Switch-Pros controller which made things easy.
Decided to go with a stealth placement of the panel in the overhead sunglass holder. Love this location as it's hidden when not being used, but also easily reached when needed. My friend and I created a mount out of ABS for the panel which came out pretty nice in my opinion.
So clean!
Took out the huge clunker of a muffler this past weekend. Summit racing straight thru muffler with the stock resonator in front of it. Sounds good with no drone. We’ll see how long the summit muffler lasts haha
So clean!
Clean and mean! Beautiful!
Bought OEM chip key from dealer and had them cut according to manufacturer key code. 5 key insert / 6 door open programming worked like a charm. I'm going to get a cheapo chip key and copy from the new cut. Master key will go to storage.
Dump run with the family.
The toddlers love the digger smashing metal
Clunk be gone!
After what was probably 2 years, I finally found the source of my steering clunk. This annoying situation would happen on washboard type roads and was especially noticeable at low speeds when turning and going over driveways, speed bumps, or even a slight road seam- it felt like extra bump steer and a clunk in the steering rather than from suspension. Turns out it was a thread I knew for much longer but never considered as most of my applicable parts were new.
https://www.toyota-4runner.org/471229-post13.html
The steering sliding yoke was the issue. It took less than 3 minutes to fix- reach into the wheel well, loosen the 2 bolts, slide the yoke just a touch toward the upper shaft and torque it back down to spec (aka tight enough and then comment "this ain't going anywhere"). It was immediately obvious just how much it helped. I've been chasing steering wander and it has eliminated that as well. It drives like I got a fresh alignment now, and everything feels more connected on uneven terrain. If anyone can explain why this adjustment was needed/changed things so significantly, I'm very interested to understand this issue better.
Amazon dropped the price on a DBPower Lithium Starter to $47. I have 2 Toyota trucks and the 2002 3.4 needs a little help now and then.
_________________
2007 SE V6 Titanium
_________________
2007 SE V6 Titanium
Got a link?, they have several different amp versions and I'm not seeing that price on any of them.
Ambrose67
