Gave the Truck some Lasik yesterday! Swapped to LEDs for my Highs/Lows/Fogs. Now i'm one of those turds with really bright lights. Hey, if you can't beat em, join em, I suppose.
No worries long as you properly adjusted them to hit the road surface rather than straight into rear view mirrors. The real turds are people who install brighter lights or get a lift and do not readjust their lights.
Did some cutting and hammering to make 35s fit. This is a 255/85 Mickey on stock wheels that is the set up on my friend's 4th Gen. I will have no clearance problems, although the stock wheel makes the tire close to the SPC UCA on my truck. However, my wheels are -10 offset while the stock wheel is +30, so i'm pretty sure that 35x11.5 tires are going to be the winner. I'm planning on ordering some this week
I had a new windshield installed in my '95 SR5 today. I should have done it years ago when window gaskets were easier to come by - :doh:
Double checked them today on lunch and they appear to be ok. We'll see if anyone complains :thumb3:
Installed some goodies this weekend!
-Auxbeam 3" ditch pods
-Midland MTX275 hard mounted radio
Mounted the mic with Magnetic Mic, Offroam vent mount and 67 designs piece specifically made to work with the magnetic mic.
Picked up a replacement taillight housing while I was in Vegas today from a salvage yard to replace the one that got broken wheeling a couple weekends ago. Installed it when I got home.
Drove the Limited to LKQ and picked a brake booster pump and accumulator from a 2003 GS300. Pump tested good at the yard. It's good to have a spare.
I’m replacing the head gasket on my ‘05 4Runner. Looks like on of the injectors is questionable as well. Probably from cylinder 6as well.
Question I have… I ran across a set of injectors that a guy pulled from a 2013 with only ~10k on it. Pulled for a super charger upgrade. Could I use these on my 05 4Runner. Both have the 4.0L. But looks like might be different part numbers.
You should try them and let us know what happens!
Getting ready for the Pineapple Express coming on Thursday with Bosch Icon wipers. Spec is 22 inches driver and 20 inches passenger. I went with 22 inch passenger side wiper for slightly better coverage. 22 inch barely clears the window frame. Bring it on!
Added 3" flush mount LED pods wired to reverse lights. Had to dremel holes in the bumper to mount them, but I'm happy with the result!
Gen 5 injectors in a gen 4?
I’m in the process of a head gasket replacement on my GEN four. I pulled my injectors and had them tested and cleaned. One is bad. I found locally a guy selling a set of G5 injectors. I picked them up because they were cheap. Can I use these Gen 5 injectors in my GEN four. Both were from the 4L engine.
The extra set of injectors that I picked up only had 7500 miles on them. Would be nice to make these swap in. Dimensionally they are identical between the two.
7ron
