What have you done to your Toyota today
Lookin good Kirk!!! :cool:
I lubed the drive shafts. It looks like it hadn't been done very much before I bought it. This owner likes the results enough to keep doing it on schedule.
The driveline clunk after stopping is gone! :biggrin2: The rear slip yoke took about 40 pumps with my gun, so that should be almost 1.6 oz.
The snap-crackle-pop sound, and stinky old grease leaving the spider joints was pretty satisfying, too.
Thanks to those that posted about the drive shaft greasing results.
My camera has a positive and negative near the camera, which I connected to a 12v switched power source. Then there is the extra positive connector.... It just doesn't make sense. Especially when I have nothing to plug it into
By switched power source i guess u mean reverse + wire
Or are you using constant power on a switch
The other wire should be ground
Blacked out my headlights and grill. Headlights are TYC aftermarket.
Shut up, Sam.
It has to do with the ****ing reverse camera. Been talking to [MENTION=55855]zopperman[/MENTION] for 2 hours trying to resolve the issue I'm having and nothing is ****ing working. Now my HU is stuck thinking my truck is in reverse, but of course, the reverse signal wire isn't even connected. I've removed power from the HU and let it sit, then I plug it back in, turn the key, and it kicks right over to this. But THERE IS NO SIGNAL TELLING IT THE TRUCK IS IN REVERSE! The wire isn't even attached for the rear lights.
ysasusup.jpg~original
[MENTION=63211]emelianenkov[/MENTION] i dont know why you talk to Zak, when i am the resident 12 volt expert.
You messed with the camera settings.
You changed the camera setting from OFF to ground.
You need to press the reset button on the radio, usually in top left corner.
I dont want to hear, you did not do it. I know i didnt do it, so it must be you LOL
I was talking to Zak because he has a government job so I can distract him without feeling guilty because I'm paying his salary.
I fixed it eventually with the help of pioneer. I needed to get it working and my dash back together before class.
Not sure why the camera won't display an image. It's hooked up ok to 12v. I'll mess with it more later
I set the camera polarity to Battery, correct?
correct. polarity is based on what you using to trigger the radio to turn on camera. usually positive from the reverse line.
i let it slide for talking to zak, you are right we paying his salary!!
Red Bull Holder
I got tired of watching my Red Bull roll around so I made a custom holder and use one space where I had a blank switch.
bought set of pods, flood pattern for my fogs. I miss having them. I will be hooking them to OEM fog switch and have them mounted to the sheeting behind the bumper for full visibility.
finally found a 4th gen at a junk yard. ended up getting some switches. total $10 with about 3 inches of the harness
also got the truck inspected and one step closer to installing my 5100's
tacoma springs installed on .85
BillM777
